Bitrate setting on my 54IRs, can it be too high and effect BI performance?
105437
BIT Beta Team
Jun 8, 2015
2,242
1,090
I'm working with Ken right now to troubleshoot a performance issue when viewing the live stream of a camera in UI3. Here is my main stream encode setting used on all of my 54IRs. Would I lose any noticeable picture quality by reducing the Bit Rate to 8192 or 4096? How about the Compression setting, should I use straight H.264 and not H.264H? Thanks
Many here run the 54IR at 8192 just fine.
Every field of view, monitor/display, and eyeballs are different.
Play with the different bitrates and see if you notice a difference.
There is a point of diminishing returns and if for your field of view, monitor, and eyeballs can't tell a difference between max bitrate and 8192 or something else then you are just wasting resources.
Thanks, how about H.264H vs. H.264? I appreciate your reply!
Either one will work. H264 is the standard, but most have not had issues with H264H.
I haven't noticed a difference so I run H264
Reactions: 105437
