I've been using v4 for years and upgraded my PC while deciding to upgrade to V6 too.
I use this PC as a server too so I came from a i7-8700k to a i9-10900k so I don't think cpu power is the issue but my problem is the live streams.
I am using substreams with the multiview but when doing full screen on a camera and doing Main Stream, its so laggy. Sometimes it's like a half a second lag, maybe full second, sometimes 5 seconds, its just not smooth at all.
In V4, no issues at all. Live stream was smooth in full screen. The cameras are Dahua 4MP starlight cameras from Andy, been using them for years.
When Blue Iris is not running, the live stream is still smooth through the camera IP direct link. It's also still smooth in V4 after resetting the old PC up and testing. But if V6 is running, even the live stream through ip camera is laggy.
There something with V6 that is making the live streams extremely laggy. I've tried all options in Hardware decode, Limit decoding unless required, and in the camera settings using H.264, H.264H, H265, etc.
Frame rate is set 25, bit rate VBR, 8192 max bit rate, i frame interval 25.
The weird thing is, I have like 12 cameras in total, but 5 are identical in Blue Iris settings and IP camera config settings and only one camera doesn't lag that bad while live streaming.
The substreams don't lag though...
Also, it does it when nothing is recording. I shut off all recording and still does it during live viewing.
