Camera Configuration Help If possible
Killer Kool
Mar 27, 2015
135
4
I came across A V starcam multi lens CS667DR. This camera is Chinese junk, but it's free.
I can see the video and control it through the PC app.
I have confirmed the username and password. The factory software can be updated also. Currently connect thru ethernet cable. ONVIF Does not detect it?!!
Using Generic/ONVIF
Model is *RTSP H.264/H.265/MJPG?MPEG4
Thank you
Using Generic/ONVIF
Thank you
What does the message window show when you do a "Find/Inspect"
Opening 192.168.0.121 port 80...
HTTP Get / request...
Failed with HTTP 12029
Opening 192.168.0.121 port 10080...
ONVIF GetSystemDateAndTime
HTTP 12029
Checking for common cameras...
Foscam FI86xx/98xx compatible?
Foscam FI89xx compatible?
Foscam FI9821 V2 compatible?
Foscam FI9821 media port compatible?
Cantonk port 34567?
RTSP port open?
No automatic configuration made
Done
2025-12-17T19:06:20.000Z
Requesting device information...
Manufacturer: IP camera
Model: IP Camera
FirmwareVersion: 2.4
GetCapabilities...
Querying services
Has Imaging services: /onvif/image_services
Has media services: /onvif/media_service
Has RTP_RTSP_TCP, requesting profiles
profile token PROFILE_000
profile name PROFILE_000
profile source is V_SRC_000
profile token PROFILE_001
profile name PROFILE_001
requesting URI for profile PROFILE_000
RTSP URI: rtsp:/192.168.0.121:10554/tcp/av0_0
requesting URI for profile PROFILE_001
RTSP URI: rtsp:/192.168.0.121:10554/tcp/av0_1
Has Event services: /onvif/event_services
RelayOutputs: 0
InputConnectors: 0
Has PTZ service: /onvif/ptz_services
Done
Reactions: VorlonFrog
No it is not working. The manufacturer responded and stated it's fully onvif- it works through the OEM GUI amp without issues. Blue Iris it does not. I
Ok Finally have the main camera working . CS621sr 3 lens camera.
Rtsp port 10554
Onvif port 10080
/tcp/av0_0
/tcp/av0_1
This camera is not detect through ODM . But BI does show the main PTZ screen..... I just cant connect to the other 2 "Lens".
