Hello everyone,
I’m relatively new to security cameras. I do currently own and use a Reolink 5MP Doorbell which has worked fine, but I’ve been considering upgrading to proper security cameras for more comprehensive coverage.
I’ve done my best to research the forums and would appreciate feedback or suggestions from those more experienced than me.
Overview of My Plan
I’m looking to install two cameras to cover specific areas effectively:
Camera 1: Front Yard up to the Front Door (Close Range)
Based on recommendations from the Cliff Notes page, I’ve selected the following:
Any advice or suggestions for alternative setups would be greatly appreciated!
Overview of My Plan
- Location: Corner of my front yard, approximately 2 meters (6.5 feet) from the front door.
- Requirements: The camera should clearly identify anyone entering the front yard and approaching the front door, both during the day and at night. The main area to cover is about 4.5 meters (15 feet) in range. It would be a bonus if the camera could also monitor the parking spaces in front of the house.
- Lighting Conditions:
- There’s a streetlight near the yard, but it’s relatively dim, leaving the area semi-dark at night.
- A light by the front door stays on all night but would preferably be switched off if the camera can perform well enough in low light. If necessary, I could set the light to activate using motion detection.
- I've attached screenshots from my current doorbell camera to provide an idea of brightness with the light on and off. Please note that any foliage visible in the attached images will likely be removed in the near future, so you can disregard it as a factor when considering the camera’s coverage.
- Location: Positioned to monitor a larger area, with a focus on the parking spaces in front of the house.
- Requirements: The camera should identify individuals at distances up to 15 meters (50 feet). Its primary function is to capture activity near the parking spaces and anyone entering the front yard.
- IPC-T54IR-AS-S3 (2.8mm focal length) for the first area.
- IPC-T54IR-ZE-S3 (varifocal lens) for the second area.
