Camera not recording at all
Joe11
Apr 14, 2017
24
3
Hello, using BlueIris on my Windows 11 PC - I added an IP camera to the network, and tried to get it to record based on motion. I can't seem to get it to record any activity at all. I can manually trigger the camera (right click/trigger) and it records, but it doesn't record based on any movement at all. My settings are at the imgur site below - what am I overlooking? Any help would be appreciated :)
Oh - forgot to mention - If I change it to "Continuous" instead of when triggered, it records.
Change algorithm to simple and uncheck the "object travels X pixels" box and uncheck the reset detector box. Both of those are to knock out false triggers and you have the opposite going on. None of my cameras use either one.
Reactions: misterfredsr
Some quality time reading the Help File is in your future.
True - I didn't think this was causing the issue since it worked earlier with the same settings. Imported the same settings, so expected it to work. I will need to spend more time with the help file for sure
