cat 5 wire
Mac25
Aug 14, 2016
19
11
Ms Gulf Coast
i've been using pre-made cat 5/5e utp pure copper stranded from monoprice for poe cams since i set up
a system just before registering here with no problems, reading thru the site and the wiki when i can i
wonder if i should rewire, my longest run is 1-100ft 2-50ft and 3-25ft runs on poe, most all the solid wire
is 1000ft spools then tools and terminals, put it simple, what would i gain ?
Reactions: Flintstone61
If its working, why mess with it?
yea forgot about sig list, corrected, will leave system wired as is, thanks.
With 6 cameras and your distance, you will be fine with Cat5
Most of the time your bottleneck will be your network hardware.
Reactions: sebastiantombs
