Dahua - NVR2108HS-S2
Qre81
Mar 29, 2026
2
1
Serbia
Hi gents,
i know old device but works great, anyhow got some 4 new IP cameras with H.265+ on them, but my NVR is on v3.205 and can not see it, until i modify cameras and lower them to H.264
i just want to upgrade my device to v4xxxxxxxx since Dahua says it can, but to do it i need some bloody middleware version cause it wont accept any of v4 i downloaded and try over USB, WEB or Config tool
if someone can help to give me link or tell me where i can find this i would buy him 10000 beers, since i was not able to find nothing ,nowhere
my device spec ;
DHI-NVR2108HS-8P-S2
system version 3.205.0000000.0
build date 13-10-2017
web version je 3.1.0.66469
PN : 1.0.01.23.11243
i need bloody v3.210 or as i read on forums or AI , ;DH_NVR2XXX-S2_MultiLang_V3.216.0000002.0.R.190621.bin
many thanks guys,
cheers,
Hi gents,
my device spec ;
DHI-NVR2108HS-8P-S2
many thanks guys,
cheers Geometry Game 2,
From what I’ve seen with older Dahua NVRs, some S2 models require an intermediate firmware before jumping to V4, otherwise the update will be rejected. You might try checking the Dahua firmware archive or asking an official distributor, because many of those older firmware files are no longer publicly listed.
H.264.h is better quality anyway.
H.265 as implemented by Dahua is a waste of time. Hard drives are relatively cheap
hi guys, i did manage to contact local Dahua re-seller and they gave me latest FW , basically same as mine 3.205, just it had 99 at the end ... with that i flashed NVR and confirmed there is no v4 for my device, ..so nothing more i can do except to enjoy with that as all seems to be working...and for H.264 and H.265 as i tested , there is no difference besides compression of files on disk,
cheers
