Desiccant test#3
Feb 4, 2020
8,109
12,890
Minnesota USA
Ok I finally FAFO'ed my way into camera reconditioning 101 with moisture issues. ( IPC-HFW5231E-Z12)
I taped the access door with Alum Duct tape, even though the seal appears fine.
I did notice something i missed earlier. There is a small "tab" on the frt. rubber gasket, which corresponds to a tiny cut out on the camera body. Which means it only fits one way. I assembled it before without seeing it. So who knows if I had it together right last time.
I "3 bag"ged it with Desiccant bags, 1 in back and two near the lens. This is all the cord i have outside at the moment.
So I've got it aimed at the street so it wasn't so boring to watch the camera.
luckily somebody parked there and I screwed around and zoomed in and was totally surprised to see his plate in color.
We recently added a big ass "Light of the Sun" yard light as you see, glowing in the back yard. :)
Zoom says it's at position 865 on the slider bar.
I quickly fixed the "stargazing" shutter speed to 1/100 and opened the Iris about 95%,
before he moved. Don't think i can capture a moving plate in this scenario, but mostly it's just out there in the weather
where the sun will bake it and thaw out the moisture and then we'll see how it goes for 24-48 hours.
We recently added a big ass "Light of the Sun" glowing in the back yard. :)
View attachment 233550View attachment 233553View attachment 233554View attachment 233555
Oh, man...is that a poor ol' Black & Decker Workmate out there in the snow near the house in image #2?
You are correct sir. How else can you "bench test" :)
I still have one from 1972 82.....love that thing. Hard to believe it's 53 43 years old.:lol:
I still have one from 1972.....love that thing. Hard to believe it's 53 years old.:lol:
I bought one for the condo job around 2017-18. then I needed another to use for a quick setup/ takedown work table for the scrap $25 table top from menards.
these are by no means as well built as the 1972 model depicted.
Reactions: JDreaming
Well 3 days in and some good temp swings and bookoo sunshine and 2 snow events and its still fog free.
Ok Day 5 with snow and temps swinging from -5 up to 28 with Sun and clouds mixed. I think I can trust it now.
Now I need to run more cable. I have the other Z12 running now as well day 2 in the garage with the cracked glass.
But I bought a broken /as is Lorex for $17 bucks just for the front glass assembly. Looks like a snip job on the data cable, somebody tried to Use a punchdown jack to revive it and failed.
Cam#2 of my IPC-HFW5231E-Z12E collection is out there now in a snow storm with 3 Desiccant bags inside. I talked to Empiretech Andy and he has the front cover(s) but shipping tariffs from China would be like $50 bucks.
So I took clear caulk and a razor blade and worked the caulk into the cracked glass, and scraped away the excess and now it too, is performing well with about 48 hours of uptime and another 24 hrs. outside in the weather.
