mat200
IPCT Contributor
- Jan 17, 2017
- 18,922
- 31,646
Hi Carm,
Here's my notes on locations to consider and number of cameras for coverage:
How many cameras do I need?
That's a difficult question to give a good answer to as it varies depending on the quality of the camera and what you are attempting to accomplish. I have seen 32 cameras in just one pharmacy, so you should not be shy about installing more cameras than you initially imagined.
For a modest house expect decent outdoor coverage with 6-8 good cameras. For better coverage and / or larger houses / buildings plan on getting a system which can support up to 16+ cameras.
Recommended Locations for outside cameras:
( For modest sized houses cameras can cover multiple areas - example one of the front of the house cameras can cover parking area, expect to use 6-8 cameras for a modest size home. )
2x for front of house
1-2x covering car parking area if outside
1-2x covering front entrance
2x covering side of house ( one on each side )
2x covering back of house
1-2x covering each entrance
1-2x covering sidewalk / street in an attempt to ID vehicles ( you may need a better "zoom" for this camera )
0-1,2x dedicated to read license plates ( LPR ). Note you will need to adjust/tune this camera to be able to read license plates.
Recommended - optional - locations for indoor cameras: ( If wiring a new house add cat5e/cat6 connections even if you decide not to include cameras )
1x camera per each entrance
1x camera in the garage
1x cameras hidden facing out from the TV/media center area at face level
