Hi all!
Hoping someone can give me some tips on installing an outdoor camera with a corner mount. I was planning on using a corner mount so I can cover the front and side of the house and was planning putting the mount high enough where it was out of reach and then run conduit down the side of the house with other wires and install an electrical box and then punch a hole behind it into the garage to get the wire inside.
I'm lost on how to protect the wire and keep everything waterproof in conduit as the main hole where the wires run in the corner mount is 1 3/8". I have an outside electrical box that is 3/4". Do they make an adapter or what do you recommend I do as I am assuming there is some sort of solution for this. I figured I could get flexible conduit and attach it to the mount and run it down to the electrical box and attach it there and be done and simple
The camera is a Clearview IP-PTZ-889 and I think its also know as Dahua model sd40212s-hn
Thanks!
Dan
Thanks!
Dan
