HIK camera toggles between night mode and non night mode every 10 seconds
daveqrj
Jan 10, 2025
23
1
Mars
Hi there,
I have this camera that I have just set up: DS-2TD2617-3/V1
Approx every 10 seconds I hear a 'click' from the camera and it toggles between night mode and non night mode. See attached screenshots.
It is powered with PoE.
Why does this happen and how do I stop it from doing so?
The camera is in a room that is in completely darkness, so there is no light disturbing or triggering the camera.
Infrared is light and you are getting a ton of IR bounce off the cable or whatever it is that is making the sensor think there is enough light to go to color.
Get that bright white thing out of the field of view.
Also get the camera off of default settings. Once you speed up the shutter, this kinda stuff goes away.
This
IR bounce back
Thanks a lot for your replies!
I tried to change the angle of the camera to something where I do not think that I have any obvious things that makes the light bounce back - but the problem persists.
Or do you still think that there are bounce back here that makes trouble? New images attached.
How to change and what shutter settings do you recommend?
Yeah that is still a lot of IR bounce.
In terms of getting the most out of the camera, here is my "standard" post that many use as a start for dialing in day and night that helps get the clean captures and help the camera recognize people and cars.
Every field of view is different, but I have found you need contrast to usually be 6-8 higher than the brightness number at night.
We want the ability to freeze frame capture a clean image from the video at night, and that is only done with a shutter of 1/60 or faster. At night, default/auto may be on 1/12s shutter or worse to make the image bright.
In my opinion, shutter (exposure) and gain are the two most important parameters and then base the others off of it. Shutter is more important than FPS. It is the shutter speed that prevents motion blur, not FPS. 15 FPS is more than enough for surveillance cameras as we are not producing Hollywood movies. Match iframes to FPS. 15FPS is all that is usually needed.
Go into shutter settings and change to manual shutter and start with custom shutter as ms and change to 0-8.3ms and gain 0-50 (night) and 0-4ms exposure and 0-30 gain (day)for starters. Auto could have a shutter speed of 100ms or more with a gain at 100 and shutter priority could result in gain up at 100 which will contribute to significant ghosting and that blinding white you will get from the infrared or white light.
Now what you will notice immediately at night is that your image gets A LOT darker. That faster the shutter, the more light that is needed. But it is a balance. The nice bright night static image results in Casper blur and ghost during motion LOL. What do we want, a nice static image or a clean image when there is motion introduced to the scene?
In the daytime, if it is still too bright, then drop the 4ms down to 3ms then 2ms, etc. You have to play with it for your field of view.
Then at night, if it is too dark, then start adding ms to the time. Go to 10ms, 12ms, etc. until you find what you feel is acceptable as an image. Then have someone walk around and see if you can get a clean shot. Try not to go above 16.67ms (but certainly not above 30ms) as that tends to be the point where blur starts to occur. Conversely, if it is still bright, then drop down in time to get a faster shutter.
You can also adjust brightness and contrast to improve the image. But try not to go above 70 for anything and try to have contrast be at least 7-10 digits higher than brightness.
But adjusting those two settings will have the biggest impact. The next one is noise reduction. Want to keep that as low as possible. Depending on the amount of light you have, you might be able to get down to 40 or so at night (again camera dependent) and 20-30 during the day, but take it as low as you can before it gets too noisy. Again this one is a balance as well. Too smooth and no noise can result in soft images and contribute to blur.
Do not use backlight features until you have exhausted every other parameter setting. And if you do have to use backlight, take it down as low as possible.
After every setting adjustment, have someone walk around outside and see if you can freeze-frame to get a clean image. If not, keep changing until you do. Clean motion pictures are what we are after, not a clean static image.
Again thanks for your great explanation and help!
Would you know where I find the shutter settings? It seems like I can only find the settings for exposure etc, but not the manual and custom shutters.
(On the IE web control panel)
Shutter and exposure are the same thing.
Reactions: alastairstevenson
Haha - thanks ;-)
I tried to follow your guide, but it seems like I only have one setting for exposure (shutter) and gain, and not one for day and night respectively.
Also it seems like my IR is not turning on at night, now that I have moved the camera to the final location. Any idea what to do?
I attach a few screenshots of the current settings.
Strange that there is no "Image Parameters Switch" on that model.
Curious what other options are available for "Day/Night Switch"?... scheduled?
And what options are available for "Scene Mode"?... also, what settings are available under "Other"?
Reactions: johnfitz
