fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,419
bit rate is dependent on many factors including compression..thou every modern camera supports h.264...you can set a max bitrate on any camera.Isn't it Bit-Rate? Isn't bit-rate dependent on the format of recording such as MPEG, H.264, and so forth? I just look at specs of certain cameras and it seems to suggest this. Also the recorders advertise total bandwidth they can handle.
Look, bandwidth is absolutely not an issue with ip cameras.
