IPC-T5442TM-AS-LED Latest New Firmware
EMPIRETECANDY
IPCT Vendor
Nov 8, 2016
9,693
28,557
HONGKONG
Hey Guys
This is the firmware for the models with LED light only or NONE LED Light Full color models.
List Support.
IPC-T5442TM-AS-LED
IPC-T5241H-AS-PV
IPC-T5541H-AS-PV
IPC-HDW3849H-AS-PV
IPC-HDW3449H-AS-PV
IPC-HDW3549HP-AS-PV
IPC-HFW3449T1-AS-PV
IPC-HDBW5541R1-AS-PV
IPC-HFW5442T-ASE-NI
IPC-HDBW5442R-ASE-NI
IPC-HDBW5442R-ASE
New Features:
1.For 8-MP cameras of HX5XXX model, the maximum resolution of snapshot can be set to 8 MP. It is 4 MP by default.
2.Select Smart Illumination on the Fill Light drop-down list, select Auto on the Mode drop-down list, and then you can set the brightness upper limit of the white light.
Fixed Bugs:
1.The image effect is optimized when the red and blue lights flash at night.
2.In the smart illumination mode, human targets cannot trigger the automatic switch of the white light in some scenes.
3.DMSS cannot receive the event after the sound and light device is disarmed with one click.
4.IPv6 configuration is deleted after upgrading to a new program.
Platform Information:
1.CGI testing tool version: V2.91.1.1
2.ONVIF testing tool version: V20.12
3.ONVIF: Supports ProfileG, ProfileT, ProfileS
Can I please double check Andy? I have two of your cam's ipc-t5442tm-as models. I am not sure about what is meant by "LED light only or NONE LED Light Full color models". Is this update compatible for my cameras? Cheers! Mat
LED one is the camera with LED light, the IR light one better not use this one, this one will be NONE Smart IR, so this is a fw for LED Full color model.
Thank you Andy!
Will this work for a IPC-HDW3549H-AS-PV?
E.g. DH_IPC-HX5XXX-Volt_MultiLang_NP_Stream3_V2.840.0000000.10.R.210930 and use the largest file "DH_IPC-HX5XXX-Volt_MultiLang_NP_Stream3_V2.840.0000000.10.R.210930.bin" from inside the .zip via the camera's web interface?
Is there ever a time that the "firmware.bin" or "General_IPC-HX5XXX-Volt_MCU_V2.840.0000000.10.R.210930.bin" files from the .zip are needed with this series of cameras?
This firmware has been updated to the 2022 version now
why General_IPC-HX5XXX-Volt_MCU_V2.840.0000000.10.R.210930.bin can not be flashed? (10 kb size)
Can this work for IPC-HDW5442TM-AS-LED Dahua model? Will it support smart illumination of white LED (human detection) without active deterrence?
That is the first model listed above as the supported models...it will not provide for the white light to come on during motion - LED is either on or off.
Reactions: remlemasi
Thank you! Just wanted to be sure no issues between Loryta and Dahua models. I know they are the essentially the same but just wanted to be sure!
Not a problem unless you have a Chinese region hacked camera, otherwise good to go. Folks here will interchange the firmware of Dahua and Loryta all the time.
