LaView vs IPCamTalk cam?
HelloAgain
Jan 26, 2019
36
26
I'm trying to compare/contrast cameras. Can you tell me the difference between the Laview and IPCT Bullet cams? They both appeared to be rebrands of the same HikVision Camera.
IPCT: IPCT-HFW4830S-I - https://www.amazon.com/IP-Cam-Talk-Network-IPCT-HFW4830S-I/dp/B07MH6K1RW
LaView: LV-PBK80804C - LaView IP Cameras
I do like how the IPCT camera states "Up to 8 megapixel high resolution. Max. 3840x2160@2160 fps" 2160 frames per second is impressive! heh
Reactions: Mike
