limiting false alarms
greg56
May 20, 2026
9
3
indiana
Are there any experts on how to limit false alarms on a lorex system .. it's got the "SMART" motion type that appears to work well .. but it seems to be only with regular motion activated ... the regular motion senses way too much (shadows, bugs, wind blowing leaves, etc...) ... if I could just separate the too functions ... tech support is no help, they hire people to read from the manual ... the fine turnings are not in the manual .. the cameras are looking around the house back at the house ... asking a camera and computer to think is maybe over the top ... any comment is helpful in the matter ...
What camera model?
But yea if all it has is basic motion with smart layered on top, then you would need a VMS like BI and use AI to stand a chance at reducing.
another idea (looking for zero false alarms ... stationary cams indoors looking at doors .. or possibly outside 5-10 ft looking at door or looking out and down .... which is best ... I know birds trigger alarms and that false is alright ...
Birds, nor car lights nor elephants set off false alerts on a system with quality equipment and properly setup
I don’t use Lorex.
That said, just by the description “Smart” motion type it sounds like Dahua’s SMD
It detects any movement within the camera view, is not precise, and is inferior generally speaking to AI/IVS where you can specify a line, direction, and sensitivity as well as target (human, vehicle, animal)
It’s slightly better than old fashioned pixel change Motion Detection, but not by much
Sadly you have to either live with it or up the quality of your gear - either better cameras or as I mentioned BI with AI. You could also get a Dahua OEM NVR since Lorex is also made by Dahua, but using the AI of the NVR greatly reduces the capabilities of the NVR.
My neighbor started with that system and slowly upgraded to better cams with IVS rules.
Motion with Smart detection is just cheaper way to try to eliminate triggers, but they still happen way too frequently.
A camera with IVS AI will knock them out.
well how's about false alarms caused by the clouds changing the light from bright to dim during the day or at night when the cam goes inferred... or the wind causing the tree limb shadows to move around ... still can that be eliminated completely? ... also what brand has what you say is the best for eliminating false alarms?
Yes that’s easily eliminated and has been for years with AI/IVS technology.
Old fashioned MD by and large just senses a change in the contrast of a pixel and calls it an alert. That’s why clouds and shadows activate it.
The technology is 15-20 years old
SMD is a half assed attempt to layer old tech AI on top of dumb MD.
Dahua does a great job
Dahua does a great job ... got any links ... where to buy ... more info ...
Empiretech is Dahua OEM. Go with the 54IR series or 4k-T.
Andy who owns EmpireTech is the go to for many on the forum
He has his own forum here
Yes match the NVR to the cameras.
Contact him through direct message
@EMPIRETECANDY
You can use the Lorex NVR, but it will limit the capabilities of the cameras.
My neighbor used his Lorex and slowly replaced cams and after he got to the 4th Empiretech camera, he then replaced the Lorex NVR.
But that combination of NVR and cameras would be our suggestion.
Yes, the kit is very nice and best for money, and must smarter than the old lorex things.
