Live view screen layout
tigerwillow1
Jul 18, 2016
5,690
12,975
USA, Oregon
With Dahua's smartPSS utility there's a really nice feature where you can define a screen window layout (2,2, 3x3, etc.), then drag any camera from a list to any of the windows. Really fast and easy to change the camera view on the fly. Is there something similar in BI and/or UI3? (I obviously haven't found it on my own).
Top right, select the pencil icon next to the gears. The black around the cameras will turn green and then move the cameras around and then hit that icon again when complete.
Reactions: JNDATHP
Also know this is a per group setting. So you will need to update any groups if you want them in a specific order.
There is also a right click menu when you are in this mode that allows you to remove names, borders, and such.
Reactions: JNDATHP
Wow, that works pretty nice. I see that when the view is rearranged, it also mirrors to UI3. Is there a way to change the camera layout from UI3? I'm not finding it there.
How do you "move the cameras around"? Dragging doesn't seem to work. Only way found is the "Quick layout" that has 3 options. I cannot reproduce the same layout on 2 installations.
EDIT: drag and drop does work... you just need to drag further... I guess.
