Long Range LPR Camera?
blounsbury
Mar 22, 2023
8
1
Phoenix, AZ
Hi folks,
I'm having a hard time finding a LPR that fits my needs that is <$1300. Hoping folks here may be able to help.
My house is on a cul-de-sac and the ideal place for me to capture license plates is at the entrance since that lets me capture incoming and outgoing vehicles. Capturing infront of my house or near by will be really challenging because my house is set back 40-45ft from the street, so capturing near the house would mean very large angles. The closest I can capture is at 110ft (25 degree angle). Other options are 150ft (17.5 degree angle), 175ft (15 degree angle), and 200ft (13 degree angle, end of street). Ideally I'd like to capture at 200ft and I'd really like to avoid capturing at 110ft (wider angle and possible interference from neighbors parking).
What options are out there that can capture day and night at 40 mph (or higher) we have some stupid ass neighbors, and anyone committing a crime will have ample time to get up to this speed or higher as they make a run down the road since im the second house in the cul de sac and im 200ft from the end of it.
I have a unifi protect system, and their LPR is good for like 50 feet max. I'd put an AI port in place to do the LPR work. I've only found the Axis Communications Q1800-LE ($1900) and the older Q1700-LE ($1300) which have a range of 50m or 100m with an optional IR Illuminator.
Any other suggestions before I pull the trigger on a Q1700-LE?
People us the $280 Z12E for those distance ranges.
It won't read plates, but if you have Unifi doing that, you don't need to pay for a camera with ALPR capabilities.
At night, we have to run a very fast shutter speed (1/2,000) and in B/W with IR and the image will be black. All you will see are head/tail lights and the plate. Some people can get away with color if they have enough street lights, but most of us cannot. Here is a representative sample of plates I get at night of vehicles traveling about 45MPH at 175 feet at a less than ideal angle from my 2MP 5241-Z12E camera (that is all that is needed for plates):
Super helpful! I don't need a camera to do the ALPR since Unifi will do it, but I thought I needed an LPR camera to get the required amount of zoom and IR illumination. I'll give the Loryta a shot, and if I'm happy with it I'll use it, and if not I'll return it.
Did you add an external IR light or is that with the light that is part of the Z12E.
The Z12E is the camera of choice by most here. Tons of examples in this LPR subforum of the capabilities of this camera. This camera is a Dahua OEM.
You simply need a camera with the right amount of zoom and the Z12E at 60mm comfortably gets 150ish - some have stretched it to 220 feet with additional IR.
Mine is without additional IR and it is a dark street. This is an older Z12E. Some have said the newer one isn't as strong, but even if you needed to add an external IR it is still cheaper than you were looking at.
You can see the less than ideal angle of mine in this day shot:
Z12E - 120ft
HOAEntranceVPN_EntTag_main_20260406003432_@9.jpg HOAEntrP2P_EntTag_main_19691231190000b_@2.jpg HOAEntrP2P_EntTag_main_20260504112028_@2.jpg HOAEntrP2P_EntTag_main_20260503102651_@2.jpg HOAEntrP2P_EntTag_main_20260503153544_@2.jpg
Reactions: Valiant
Why spend 3-4X the money?
Yeah we have quite a few here too, generally not a problem.
If you decide with Axis, either Q18xx-LE or Q17xx-LE series will serve you well. I use 6-7 year old Q1785-LEs for LPR purposes. The below camera is mounted about 100 ft from the location where the picture is being captured.
I use paid BlueIris, free CodeProject.AI and free ALPR database to collect the license plate info.
Do you have a more current guide for this? "I use paid BlueIris, free CodeProject.AI and free ALPR database to collect the license plate info."
Get BlueIris installed, I use V5.
Get CodeProject working. You have a choice on what type of OS to run it on.
Get a Docker and get ALPR database working.
Now, that I "hear" BlueIris V6 can do AI, so if you go that route, you may only need ALPR database. You'll need someone else to guide you thru.
Hi folks,
First, I dont recommend the LPR with worm light solution, even though you can see the full color video or image at night, in some state it might cause license plate overexpo, especially for the license plate with a white background.
If you consider a low cost solution I recommend LPR431-Z8, a 5X zoom lens LPR Cam, you can ask Andy from empire tech, he have that solution.
