If you are looking for a special mount that you can’t find to fit your cam, I can help you out. You can find these on EBay, but most are a universal fit. I can fab to your specs and ship them directly to you anywhere in USA via USPS Med. Flat Rate Box. Most corner mounts will fit in one of these. The bracket will have the large 1.25” dia. hole punched in the face, but you will have to drill the other holes. This way it will fit your mount perfectly and you can locate the screw holes where needed. This is nice for brick mounts.
Look at the drawings and let me know your dimensions. For example Dimension “A” is 5.25” If you need something out of the ordinary, I can make it. Most corner brackets will run around $25 plus 13.60 Priority Flat Rate shipping (2-3 days) They will be made out of 18 ga. galvannealed steel ready for you to paint your color. I can also fabricate these out of .100 mill finish aluminum for a few bucks more. Once you PM me your dimensions I can send you a PayPal Invoice of your exact cost.
Please Note: Due to my retirement, I no longer fabricate these.
