Hi All,
My Loryta IPC-T5442TM-AS-LED S2 arrived yesterday after purchasing it from Andy's Amazon store.
I wasn't able to find how to control PTZ, and after poking around for a while I decided to upgrade it's firmware... Yes, I didn't read not to do that on the forums before hand.
I ended up flashing the firmware from: EmpireTech IPC-HX5XXX-Volt_MultiLang_NP_Stream3_V2.840.15OG00D.0.R.220818.bin
I still wasn't able to find the PTZ Control section on the Live view, but then reading further I realized that apparently I needed to use IE to login to the camera for more options. But, I still don't see the PTZ Controls option...
Am I missing something? Did I flash a firmware that is for bullet cameras without P/T control and the initial firmware would have worked if I used IE?
Thanks,
Dan
Thanks,
Dan
for some reason I thought it was... So, to adjust the angle should it be manually hand adjusted then?
