NVR5XXX-4KS2_MultiLang_ V4.001.0000003.2.R.201010
EMPIRETECANDY
IPCT Vendor
Nov 8, 2016
9,693
28,557
HONGKONG
Hey guys,
The latest new fimware has been released, this is the best version that we have now for the 5 series.
Attention: We don't undertake any risk that brick the NVR, If your NVR firmware still at 2018 or early 2019, Please think twice to make the upgrade. Sure the firmware only work for the original English updated models.
Updated details, please check the attached file.
Support List
NVR5424-24P-4KS2,
NVR5224-24P-4KS2,
NVR5232-4KS2(V2.0), Amazon.com : EmpireTech NVR5232-4KS2 32Channel 1U 4K&H.265 Pro Network Video Recorder English Version
NVR5208-4KS2(V2.0), Amazon.com : EmpireTech NVR5208-4KS2 8 Channel 1U 4K&H.265 Pro None POE Version Network Video Recorder English Version
NVR5216-4KS2(V2.0), Amazon.com : EmpireTech NVR5216-4KS2 16 Channel 1U 4K&H.265 None POE Version Pro Network Video Recorder English Version
NVR5208-8P-4KS2(V2.0),
NVR5216-8P-4KS2(V2.0),
NVR5232-8P-4KS2(V2.0),
NVR5216-16P-4KS2E, Amazon.com : EmpireTech NVR5216-16P-4KS2E 16Channel 1U 16PoE 4K&H.265 Pro Network Video Recorder English Version
NVR5232-16P-4KS2E,
NVR5224-24P-4KS2E,
NVR5416-4KS2(V2.0),
NVR5432-4KS2(V2.0),
NVR5464-4KS2(V2.0),
NVR5416-16P-4KS2E,
NVR5432-16P-4KS2E,
NVR5464-16P-4KS2E,
NVR5424-24P-4KS2E,
NVR5216-8P-4KS2E,
NVR5208-8P-4KS2E
Welcome to discuss for this latet new fw.
Andy
Thanks Andy,
This will be my first firmware upgrade on my new 5216-16P-4KS2E NVR. Do I need to default the NVR after the upgrade? (similar to what I did with the cameras) - thanks!
I already have this firmware found a dahua website which had the file uploaded (it's from October).
When remote open nvr webpage
(port forwarding for port 80)
the camera live view works OK
Camera web link configurations don't work.
They open internal IP of camera.
I reported to Dahua asked them to make it possible to access this remotely.
Just update it directly and make a default after finish the updating, no need to make default before updating.
Don't pull off the network cable or power off duing the updating, or else will brick.
If buy from us from 2019, can update without any problem.
@EMPIRETECANDY Bought my NVR5416-4KS2 from you Jan 1 2019. What version do I have? 1.0 or 2.0?
I have a new NVR-5216-16P-4KS2E and was wondering the same thing. I believe it is referring to hardware version. It can be found in the NVR menu, I believe it was under maintenance. Not sure what the differences are between hardware versions 1 or 2. I automatically thought I had the version '2' since I just received mine few weeks ago. Guess not.
Device Model NVR
Record Channel 16
Alarm-in Port 4
Alarm-out Port 2
Hardware Version V1.0
Web Version V3.2.7.132796
ONVIF Server Version 19.06(V2.6.1.869049)
ONVIF Client Version V2.4.1
System Version V4.001.0000003.1, Build Date: 2020-08-13
Security Baseline Version V2.1
Mine does not have a hardware version see below.
Device Type:DHI-NVR5416-4KS2
Record Channel:16
Alarm In:16
Alarm Out:6
SN:XXXXXXXXXXXX
Web Version:V3.2.3.111175
Onvif Version: V2.4.1
Security Baseline Version: V1.4
System Version:V3.216.0000006.0, Build Date: 2019-02-23
The version 3 firmware does not report the hardware version.
Hey guys,
Support List
NVR5424-24P-4KS2,
NVR5224-24P-4KS2,
NVR5232-16P-4KS2E,
NVR5224-24P-4KS2E,
NVR5416-4KS2(V2.0),
NVR5432-4KS2(V2.0),
NVR5464-4KS2(V2.0),
NVR5416-16P-4KS2E,
NVR5432-16P-4KS2E,
NVR5464-16P-4KS2E,
NVR5424-24P-4KS2E,
NVR5216-8P-4KS2E,
NVR5208-8P-4KS2E
Andy
I can offer than I'm running V4.001.0000000.3, Build Date: 2020-05-19 on my v1.0 5216-4ks2. This would beg the question if May 19 is early in the year, which I could argue either way ad infinitum.
I'm reluctant to go further without sounding like I'm critical of Andy, which is absolutely not the case. His command of English is pretty darn good. However, communicating these specific details to an English speaker takes a native English speaking nitpicker nerd. I was scared going to the version I'm running and accepted the risk of bricking the NVR. I'm scared to push my luck again. I guess the best case would be for the English speaking nerd to do a Vulcan mind meld with Andy. Short of that we have to do the best we can to help each other.
Reactions: Inigo and looney2ns
Thanks! I am still at DH_NVR5XXX-4KS2_MultiLang_V4.000.0000000.0.R.20190713 2019-07-13 and expect V4.001.0000000.3, Build Date: 2020-05-19 is a significant jump.
Andy's grasp at the English language is so much better then some of the people I work with daily in the USA.
If I had to speak Chinese, any of the dialects, I am sure NO one would be able to tell what I was saying! :banghead:
