CCTVnewbie810
I just realized my link doesn't work anymore. I have switched to TailScale from OpenVPN due to ATT fiber issues.It should be obvious if the alert is stale when you tap the Pushover message link. In my testing, UI3 will stream all the cameras.
That is, this:
/ui3.htm?t=clips&group=index
Instead of this:
/ui3.htm?rec=-1&cam=FD
Think I need to change my LAN settings so that it accesses via the TailScale IP not the LAN IP.
For some reason, since switching to Tailscale, I have to use the Local BI IP to access UI3 when at home on the network and then when I am gone, connected to Tailscale, I have to use the UI3 link with tailscale IP. Quite annoying...
