fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,419
When you use a dynamic dns service you dont need to change your external ip address (you cant anyway as its set by the isp and changes randomly sometimes only every few months on when your modem reboots) that's the whole point. The service monitors your external ip address and keeps track of any changes. The service give you a host name for example gitsipcameras.dyndns.org that host name gets redirected to whatever you external ip address happens to be at the time...so you would need to enter the hostname + port so you would enter gitsipcameras.dyndns.org:8585 if 8585 was your webserver port...for this to work you need to properly set up port forwarding...I actually had the same problem and gave up...
If if you do have another domain name or your using one of the dns services, you can not change the "external ip address" - unless I am missing something?
Another more secure option is to use VPN, so you are actually logging into your home network and you can use the local ip address to access the blue iris server.
