set up failed: 483 for 'recording 0'
Boydellis
Aug 25, 2019
9
Calgary Alberta canada
Everything seems to be working properly but I am getting this message. I have no idea what this means or how to fix this? Any help would be appreciated
Turn off hardware acceleration
A screen shot of the complete BI PC window would be helpful.
What are you trying to do ?
IS BI recording cameras and displaying video ?
Can you change to different tabs and views in BI ?
What is your hardware configuration ?
CPU ?
Memory ?
Disks ?
Video card or Intel ?
Are you recording h.264 or h.265 ?
I have a i7 9700 16 g ram 3.60 GHZ with a geforce gtx card. I'm not really sure If this is doing the encoding for the cameras or not, but there is a hashtag next to the cameras. So something is decoding.
The problem is with using the geforce GTX card or its driver. First turn off hardware acceleration using the NVIDIA, the error will stop. A screen shot of the Camera video tab, configure button result
Look at this post.
I had the same error messages, it turned out that, while hardware acceleration was working for the cameras, it did not work for the web streaming. I had to turn it off on the streaming profile.
Bumping this super old thread with a little more information because I was getting this error after updating to BI 6 and couldn't figure out where this was...
Error: HW encode - h264_qsv setup failed: 483 for 'streaming 0' check hardware compatibility
Finally found it in BI Settings > Web Server > Advanced > Encoder Profiles: Streaming 0 > Configure > Hardware Assist
edit: I think this has always been an issue for me I just never knew where to find it.
Reactions: IAmATeaf
I've also been tryng
I've also been trying to battle this same error: h264_qsv setup failed: 483 for 'streaming 0' check hardware compatibility.
I too had a look but couldn't find this setting within Web Streaming, so many thanks, here's hoping it get rid of this message :)
Just to clarify, it's in the full Blue Iris application settings under the web server tab, not the UI3 settings!
Reactions: IAmATeaf
Lol now I'm at a computer and can do this easier... good luck!
Reactions: IAmATeaf
