Using a mask for motion detection but have AI analyze entire scene?
biggen
May 6, 2018
2,953
3,388
Just figured out that if you use zone/hotspot in BI, then AI can only "see" what you have masked in the zone. I was under the assumption that you could use a mask to detect only a certain area of the scene but then apply AI to the entire scene when it comes to confirming alerts but this is not how it works.
Is there anyway to do the above? I have a scene where I only want to detect people walking on the sidewalk and use AI to confirm them. I don't want BI to detect motion on the roadway as that is an unnecessary use of AI and CPU cycles. Here is what I have setup in BI. AI can only "see" what is in the green area which means it only has legs and feet to get a confirmation which is less than ideal.
Yes, you need at least another zone that covers the rest of the scene (I use "G" for general), then trigger on the "A" zone, but have AI analyse both zones. (A and G). See the BI help file for various combinations of syntax for zone crossings.
Reactions: Bruce_H and biggen
or let the camera do the AI work and just select person. Assuming that cam has AI capabilities.
Yeah, I do a mixture of that. IVS sucks at night from my testing and years using Dahua. Hit rate is 50/50 at night. It's spot on during the day though.
Reactions: Tinman
I have the opposite experience with Dahau (in-camera) IVS: it is unbelievably accurate at night, often finding distant people deep in the shadows that BI motion detection could never hope to find, and the AI would likely reject even if the BI motion detection did pick them up.
Unfortunately, I would also like to capture animals at night, so I do still run BI motion detection in conjunction with IVS, as my cameras are S2 5442s, with no firmware available with animal detection.
Reactions: biggen
Which camera are you using?
My 5442 series cameras have been incredible at night - are you on default auto settings?
Mine works at night during a blizzard:
I will preface this next example with this camera is dialed in to this location for when the flood lights come on, so that is why the picture is so dark.
So I have several IVS tripwires on this camera instead of an intrusion because this camera also acts as a spotter cam for my PTZ and I only wanted to spot it of people heading towards and not away. Obviously at the street, this camera is not being used for IDENTIFY purposes.
Here is a middle of the night capture (the red and blue lines are the IVS rules and when it triggered). My non AI cameras totally missed this event using motion detection, including my overview when this person was in front of my house and was lit better from the lights off my house. The middle of the night, 50+ feet away from the overview cams, and dark clothing got right past the BI motion that I have fairly sensitive. So since BI motion didn't pick it up, obviously neither did DeepStack. In playback tuning, DeepStack dark model did pick it up, but we all know that tuning and live DS are two different things at the moment.
It's a 4k-T cam. No, its not auto. Settings are dialed in. It's never been very good at IVS at that distance to the sidewalk at night for me.
I ended up just using dumb motion detection in the camera itself in a zone that covers the sidewalk only. Then I trigger BI via ONVIF with that zone and BI can confirm the alert with AI to determine if it is a human or not. Working great so far and easy to setup.
Reactions: jaydeel
Trying to figure out why this particular alert was not confirmed. Shows as a person with 82 percent accuracy. Can't figure out why it didn't confirm it and left it as canceled.
Your 50ms timing is much too fast for relatively slow moving objects like people, the AI won't see sufficient motion between each analysis and will thus cancel as a static object. Try at least 500ms, or preferably 750ms or 1 second between each analysis. Yes, it's true that the checkbox for a "new alert/analysis on retrigger after cancellation" should in theory take care of this, but it may just repeat the same cycle over and classify this object as static (not enough motion between each "frame" of analysis). For some reason Ken has set it up this way, and it seems to be a much bigger problem with the new built-in Ai compared to how it worked under CPAI.
Reactions: biggen
Alright thanks. I’ll give that a try. Those were setting I am using for LPR as well but didn’t think that I may need different ones for people.
Reactions: jrbeddow
This is seemed to have fixed it. I changed timing to 750ms and then went with 2 pre-trigger frames and 2 post trigger frames. My actual trigger is only 3 seconds long so 4 frames x 750ms = 3 seconds. Seems to be working like a champ!
Reactions: anijet and jrbeddow
