Version 4.0.7
Aug 11, 2014
783
725
Like fulfilling a campaign promise, this version now supports bulk clip conversion/export! *Select one or more BVR clips on the clip list and then use Convert/Export on the right-click menu. *The process will proceed in the background. *There are also many other fixes and updates for the mobile client apps.
The post Version 4.0.7 appeared first on Blue Iris.
  • Many bug fixes and camera updates
  • It is finally possible to queue BVR clips for "bulk conversion and export." Do this by first selecting one or more clips and then you will find the new Convert/Export command on the right-click menu. Select an output format and folder before clicking OK. You will see the clips marked for export. As export completes, the clips are then marked with a solid green export icon.
  • With this version, the latest iOS app 1.40.12 will allow you to manage push notifications on a per-camera and per-device basis. On the mobile device list, hold-down the device to toggle push notifications.
  • With this version, the latest iOS app should now allow export/record of audio with the video without the massage about the video being incompatible with the Photos library.
  • Hopefully Apple reviews and releases 1.40.12 soon as it also corrects an issue with opening the app after geofence updates especially if the app was completely closed. Also, the Android developer is about ready to release an update which brings the Android app to this same feature level and version 4 skin.
