- May 20, 2015
- 10
- 10
Looking to replace some older Dahua cameras and NVR. I would prefer buying from Andy. But, I don’t see a camera on his site with these comparable specs. Will I need to venture away from Dahua for this?
There is no 1/1.2 Vario. Just 1/1.8 with 4mp.
I think he means in the budget range.it's not 100% accurate
Above 1k USD from Andy, only on special orders![]()
Afraid of that. Any other brands with those specs available to buy in US for end consumers besides Unifi?
This seems like the route I'll need to take. The price doesn't seem bad for the specs either.If you want varifocal in that sensor size, go for the Ubiquiti G6 Pro Turret![]()
True, this is especially due to the fact that the end user has no way of setting shutter speed / exposure. Biggest fail from Ubiquiti - also, cannot login to the camera without using UniFi Protect and dedicated NVRBiggest problem with G6 Pro is that night video quality from that camera is not so good. Both color and/or IR...
That's what I'm replacing. I have a bunch of the Dahua IPC-HFW5421E-Z cameras. I wanted to increase the FOV on some of these without sacrificing my identification ranges.Most here find 4MP is the sweet spot for these cameras based on the old tech they use. Save yourself some money and get a 4MP varifocal.
Try the G6 Pro Turret, but it from Microcenter (if you have one nearby); return it within 30 days if you don't like it. However, do please share some samples (especially of nighttime performance) here on the forumThat's what I'm replacing. I have a bunch of the Dahua IPC-HFW5421E-Z cameras. I wanted to increase the FOV on some of these without sacrificing my identification ranges.
The zoom isn't the problem, I don't think. I'd like to reduce the zoom, but maintain the same identification over a wider area. If I reduce the zoom I have now, I get more of an overview shot. I guess I could add more cameras to do identification at many more areas, but there's a ton of spaces I need to be able to do identification in. I was hoping by increasing the MP, I could get the same identification at a wider FOV.Then try the 5241-Z4E that has more optical zoom and keep the existing camera for wider angle.
Too many make the mistake of trying to use one camera for too much and sadly adding MP doesn't help.
that COMS is really big, I, too, love the visual effects produced by this camera—they are truly fantastic. I don't know if any other company have that sellection. if you consider to get that kind of product I suggest to ask him directly.Looking to replace some older Dahua cameras and NVR. I would prefer buying from Andy. But, I don’t see a camera on his site with these comparable specs. Will I need to venture away from Dahua for this?
