D dudemaar Known around here Aug 18, 2018 1,383 2,901 Canada Sep 6, 2023 #1 Can I run 300 ft of cat6 for Internet from a high end Netgear router directly to a NVR for internet remote viewing? or would a good switch to the NVR be a better way?
biggen Known around here May 6, 2018 2,953 3,388 Sep 6, 2023 #2 Sure. 300’ is within Ethernet specs. If you need more ports for other devices than you will have to put a switch in the middle. Reactions: dudemaar
D dudemaar Known around here Aug 18, 2018 1,383 2,901 Canada Sep 6, 2023 #3 biggen said: Sure. 300’ is within Ethernet specs. If you need more ports for other devices than you will have to put a switch in the middle. Click to expand... Thanks, I just wasn't sure if i would get a better internet signal if using a good switch after the netgear router.
