- Mar 9, 2014
- 36,891
- 21,419
- A bug fix for the software update prompt at startup
- When creating new FTP folders, if the command to create the entire tree fails, the fallback is now to create each subfolder in turn
- Each camera's digital zoom position is now memorized
- The Schedule control now displays the number of minutes relative to sunrise/sunset as you are adjusting times
- A timing fix for the "video or snapshot each X min" options on the Record tab which may have caused them to drift from their alignment with the time of day
- The "Trigger using camera's digital input or motion" option has been expanded to include the popular cameras that use port 34567 including IPC, IPCX, CantonK models.
- A new option on the camera properties Alerts page offers to fire alerts for re-triggers as well as initial triggers. A re-trigger occurs when the camera is already in the triggered state, but additional motion or other trigger events occur.
- The Sound alert previously fired continuously during a trigger. Now like other alerts, it fires just once with the initial trigger, but again with re-triggers if the new re-trigger option is enabled.
