- Mar 9, 2014
- 36,891
- 21,419
4.2.2 - October 19, 2015
- Further refinement of both motion and object detection algorithms.
- New motion default values consist of higher contrast, shadow cancellation, and the object movement filter is enabled with 100 pixels.
- When using the highlight motion object rectangle feature, green is now used unless the object is in a triggered state, in which case it will be red.
- You may now run pre-recorded video through the motion detector for test purposes. Open a BVR file in the viewer, then right-click to find this on the menu. Settings will be used from the camera on which the clip was recorded, along with the active global profile number setting. You should start playback at least several seconds before, but optimally up to 250 frames before the point of interest in the video. The highlight motion and object setting is automatically used--however the video itself should be recorded WITHOUT this enabled, and optimally "direct to disc" so that the exact same video is going through the test as it would "live." Currently forward playback at varying speed is possible, but step and slider operation will reset the motion detection.
