- Mar 9, 2014
- 36,891
- 21,419
4.4.0 - July 21, 2016
- Foscam R2 compatibility fix
- Adjust PTZ speed from camera right-click PTZ menu
- From a user's Options/Users page, you may now choose to not use the new-alert and status counters locally and on the client apps. This will suppress the red badge numbers on the app icon and alert images as well as prevent the re-ordering of the most recent alert for each camera to the top of the alerts list.
- The WAN IP address box on Options/Web server will now recognize an IPv6 address. Provided the remote devices and your router are also IPv6-aware and you have done the proper routing, you should be able to use this IPv6 address remotely. The procedure to pull the address automatically however is still looking for your IPv4.
- If you use the /admin?camera=cam1&profile=x method, this now overrides the camera's profile in all cases unless you are overriding the global profile number and do not have the option checked on the camera's Schedule page to ignore the global override. Sending a value of profile=-1 now will remove the override.
- On the camera properties page you may now assign a keyboard shortcut to each camera so that you may quickly select/focus a specific camera.
- You may now add fps=x to a Blue Iris web server request for /h264/ and /mjpg/ video streams. Previously some users were inappropriately using the "frame rate limiting compatibility" mode for this functionality when pulling streams from other Blue Iris servers.
- As the "frame rate limiting compatibility mode" function has been increasingly deprecated, it has now been fully removed. The proper way to manage the stream FPS is on the camera/server side, not the software/client side by attempting to manipulate the receive buffer size and timing as this function once did.
- The pre-trigger video buffer on the Record tab now has units of tenths of seconds rather than frames. You may need to revisit this field to adjust as necessary for your requirements.
- A previous method of tracking alerts by file position offset in the BVR format is being deprecated; new alerts will be marked with time position offset.
- When recording using any of the continuous options, the pre-trigger video buffer setting is now used to offset the playback position of any recorded alerts.
- A few users have written to say the RTSP timecode option is not working properly, causing odd times to display on some camera streams. While it's possible to disable the RTSP timecode on the camera's Video/Network page, additional error-checking has been added to the code that makes use of the RTSP timecode in an effort to prevent erroneous times from being used.
- Camera borders are suppressed when a camera is shown full-screen and the "show camera names" function is also disabled.
