4.4.4.1- September 13, 2016
fenderman
Staff member
Mar 9, 2014
36,891
21,419
  • A bug finally found and fixed where an automatic adjustment of the "max frame rate" may cause issues with direct to disc recording dropping frames.
Reactions: bob2701
Poll!
Two (2) posts relating to the same release would be confusing.
In addition to a POLL which asks the question...
1) Release 4.4.4.1 is working well for me
or...
2) I have experienced problems running release 4.4.4.1
You should also post the release installer thereby creating an archive of all the releases and making roll-backs much less difficult.
I wonder if this is the issue I have been having for months and kept being told it's not a bug!
If only there was a way to check....your issue is directly related to reolinks failure to include an iframe interval setting....
Hmm, i was looking what version i have and i do have: 4.4.4.1 x64
Support Level: Basic
Expires: 9/13/2016 10:53:04 Am ?!?! What is this? Expire....
Your Blue Iris installation has expired @patrocle; you must uninstall Blue Iris from your machine immediately.
Reactions: patrocle
Still having the bug where cameras will completely freeze and run at 0fps until I disable the camera and re-enable.
This bug isn't present in 4.3.9.5
I'm having serious issues a couple of days after upgrading to this release. My desktop is showing through the main cameras window, I have no live view from any cameras, no new clips are being recorded, the messages window is cycling from 0 to five messages, etc. Has anyone else had similar issues?
With this version (clean install on a new machine, with an imported .reg file) playback of a rotated image crashes Blue Iris. Tried this on two cameras with very different configurations. Can anyone reproduce this?
You should email support as this is a very specific instance..
I hate to report an issue that may be unique to me. Always nice to get independent verification if I can.
