5.2.2 - March 20, 2020 Intel hardware H.265 decodingand H.264 encoding
fenderman
Staff member
Mar 9, 2014
36,891
21,419
Video components were updated and the Intel hardware decoding interface was redesigned
and recoded in an attempt to bring some missing features online such as H.265 decoding
and H.264 encoding. The 64-bit version is required for all hardware acceleration.
The BlueIrisService.exe was compiled for 64-bit and now uses updated methods to stop the
running BlueIris.exe without resorting to a force-close.
EDIT: Changes were made to the release notes in 5.2.2.3
and H.264 encoding. The 64-bit version is required for all hardware acceleration, and you
may need to now update your Nvidia drivers if you were using this. For backward
compatibility concerns for now, you must select “BETA Intel” as the hardware decoding
method on the Video tab in camera settings if you want to help test this.
The release notes have been updated for 5.2.2.4
may need to now update your Nvidia drivers if you were using this. New hardware
decoding options include DXVA2 and D3D11VA, but these may still be in “beta.”
Do all of the CPUs that support H.246 acceleration also support H.265 acceleration?
Needed to turn off HA manually
After install Intel HA cameras displayed color bars for +/- 30seconds then No Signal I/O error: 0.
Saw this thread only after error occurred; when possible, could a "Warning" is published it be linked in the new version announcement?
All you need to do is rollback to a previous version. As usual dont upgrade the second an update is pushed.
Reactions: djernie
Yep, that's what I get for being on the bleeding edge... but I did give it all of 2 hours ;)
Normally the updates are pretty solid.
Could you share where you get such detailed update descriptions? I tried to find the details about "Video component updates", checked the BI website etc. but couldn't find anything. Thank you for posting these regularly.
This is included in the help file with every release. I just copy paste.
Thank you. I didn't realize the help file is updated every time. When I browse it it always lacks explanation for some features/settings. I thought it was always behind.
