- Mar 9, 2014
- 36,891
- 21,419
5.7.3 - March 30, 2023
A new option on the right-click menu over the Viewer window allows you to modify the
now-default setting to use a BVR’s sub stream (if recorded) for scrubbing and high-speed
playback.
A small change has been made to the 5.6.8 feature which caused alerts as to be considered
locked/protected while their associated clips remain—this now applies only to the age limit
of the alerts folder. It will no longer apply to the size limit on the folder if alerts are being
saved as JPG (and .DAT) files.
You may now select to save AI-unknown faces on a per-camera basis. You may also select a
specific folder for local faces management instead of using a folder in the Program Files
folder, or you may choose to not use local management at all.
playback.
