tangent
IPCT Contributor
- May 12, 2016
- 4,641
- 3,999
I'm not advocating perfection, nor do i worship the ground beneath a copy of the nec.Sure, any of an infinite number of things could cause a serious problem.
It's about understanding relative risks, classifying hazards, and mitigating risks.
Going out of town in leaving a building with shitty electrical, unplug some stuff and turn off some breakers.
Live there, make sure your fire extinguishers work and everyone can escape via the windows, smoke detectors work, sleep with doors closed, etc.
Run 10-3 in a buried conduit with ethernet, use a GFCI breaker or run fiber optic for a couple hundred more or just run a second conduit.
Little things inexpensive things can create big hazards. Things like: Shitty backstab outlets, not tightening screws or lugs enough, driving in wire staples until they damage the romex, accidentally nicking the wire when you strip it cutting half way through it, ignoring a hazard that keeps tripping a GFCI and just resetting it constantly, shitty neutral connections. In the case of older homes, sometimes the wiring insulation just starts to break down
This was and has been seen with GFCI's as we all know the first, second generation of these devices consumed more standby power while false tripping!
By the time AFCI's were code the technology was already in its 2nd / 3rd iteration and like the GFCI the vast majority of problems were solved.
