Acceleration for Built-in AI?
TheWaterbug
Oct 20, 2017
1,341
2,322
Palos Verdes
I'm doing LPR from 4 cameras in an office park, and feeding that into the ALPR Database.
I also have 20+ other cameras doing regular monitoring, and my CPU is hovering around 50-60% when there's not a lot of traffic, but during peak traffic times it can peg, especially when the Docker container for the ALPR database starts mishbeving.
I was thinking that offloading some of the AI burden might help. I was running CPAI on the same box as BI, and recently switched to BI 6's built-in AI.
Given that the built-in AI runs on the ONNX runtime, which uses DirectML, which requires only DirectX 12 support, it seems like there should be lots of options.
How much VRAM do I need for LPR? This card is only $50 at amazon, but it's got only 2 GB. For $57 I can get 4 GB. edit: that one's DirectX 11.
What's a decent minimum spec for this type of application? Does performance fall of a cliff with insufficient RAM? Or does it degrade gracefully?
Going to 8 GB puts me into far more expensive territory for a science experiment.
Thanks!
Is there a way to see how much BI' Onnx-based AI is using? I expanded-all in Task Manager, and I don't see it as a discrete thing.
Nvidia 700 series graphics cards are 13 years old and out of driver support. Those are particularly low end models too with low memory bandwidth. I wouldn't expect them to accelerate anything. Best you could hope for is to offload some of the work from the CPU and system RAM, but even then I wouldn't hold my breath.
You might want to try one of the laptops with a built-in nvidia GPU, like this one:
It's $150 (assuming you have an extra 256G nvme, and 8G of ram, and a USB-C charger that does 60W). These have a Nvidia T550 with 4G of vram, and 12th gen Intel CPU with iGPU. You could run CPAI with either GPU. T550 is pretty new, full driver support.
I am not sure getting a different GPU is going to help when 3090 and 5090s aren't cutting it. I think BI uses DirectML which doesn't use CUDA directly so it will bang quite a bit on the CPU. I think I am going to go back to Codeproject which can use Cuda directly. Is it possible to get all the same models working on that?
