Alert image not created
tibimakai
May 8, 2017
1,059
540
Los Angeles
The system worked great for years now, but lately I'm having issues with the LPR camera.
It's getting stuck and it shows the yellow exclamation sign. What I mean, for example in the morning I check the camera and it still show a night image.
If I soft restart it via GUI, it goes back to normal.
Lately it's happening almost daily.
Camera is sharing a line with another camera, I'm using a basic splitter to split the signal. Sometimes, cameras that are using splitters, lose their signal, but after a restart, or a few restarts they always come back online.
What could be the issue?
Any help would be greatly appreciated.
I would check the wiring/connections first to eliminate that aspect. It could be a bad or corroded connection. I presume you are using a POE combiner/splitter for the 2 cameras? If so, I would replace it with a new one
I will check that, though here in LA we don't have much rain and all my cameras are under the eve.
But it might be possible that the splitter/combiner is failing. I would try replacing it, they are cheap enough
I can do that too, I have an extra one. Thanks
Reactions: JPmedia
