American Flag Placement - Opinions?
IReallyLikePizza2
May 14, 2019
2,675
6,195
Houston
I can't decide if I should go higher or not, if this flag is just too big for this location or if I should choose a different location entirely?
+1^^^.
IMO, a 4x6 or 3x5 flag should be fine at that height and should fly well if not surrounded by structures or trees.
My only suggestion would be to lengthen the flag pole just enough to insure the flag does not touch the roof edge anywhere and get snagged and damaged. Moving the mount down in conjunction with that may help.
You do plan to light her up at night, right? :cool:
I agree with TonyR. Lengthen the flag pole and lighter her up at night!
End result, ended up taking the advice of not letting it hit the building so I installed it on the peak
Just got all the conduit and fittings, just gotta get digging!
Reactions: Broachoski
That particular setup seems fine. I assume that's a 5' flagpole? Get a 7' one that allows you to take one link out of it to shorten it for a 3x5 flag or go with 7' for a 4x6 flag. I have a 3x5 flag that sits higher on a tree. It specifically is set high because it's right near the road and I did not want some anti-American tard to eff with it. I do use a ladder to hang it. I'll try to take a pic tomorrow.
I have 2 spare rods, so I can make it longer if needed
It can't be seen back there. Also, don't listen to me, because I'd have you do this. Too big is like a girl too pretty, or a car too fast.
attachment.php
Oh trust me, one is going in the front! This is the test case
But, you can see it from the street!
I am tempted to get a big pole in the front
Quite a few of my "neighbors" will be quite offended by the flag, they would rather fly a different one
Looks very nice. :)
I have 2 of these stuck in the ground and switched with a photocell. You could remove the stake, mount below the eave and point one at your flag. I ran a bead of silicone around where the lens meets the metal, just in case. They've been in place 2 years now. The pole is 20 ft. so I have 2.
EDIT: mine are 120VAC, there are low voltage versions as well. :cool:
Amazon SPOTS
Home Depot Photocell
attachment.php
Nice! Old Glory at her finest.
But, IMO one can have too big of a flag if it's on a vertical pole and it just hangs and never unfurls. The bigger the flag, the more wind it takes to fly which in turn generally requires more height, depending on the area. And of course, nearby structures and trees can negatively affect that wind.
This flag at a Chevy dealer in Jasper, AL is H-U-G-E......and it's on a very tall pole, on slightly elevated property and far away from structures and trees. I don't know pole height or flag size. The pole is so tall the flag even flies well when at half-staff, as shown.
3x5 flag on a 6 foot pole. The flag holder base is 11' 4" off the ground; the bottom of the flag is 7.5' off the ground when the wind isn't blowing so hopefully I don't get an America hater setting it on fire.
p.s. Happy 250th B-day America, revolution every time, all the time against tyranny!
Reactions: TonyR
Got a good drone shot
Meant to post to this thread, but managed to post it to an unrelated thread...
The Harley dealership off I-205 has a yuuge flag that the communists commuting to Portland are confronted by as they are stuck in gridlock traffic.
I should mention, not me BTW. I ride a ricer.
