Android App Connect Problems
Rob2020
Oct 2, 2020
1,098
2,738
OR USA
Hello all, been fighting this off and on today and hoping someone smarter than me (that would be most here:p) can help me out.
Running Blue Iris 5 purchased here about 6 mos ago, added Blue Iris Android today from the Play Store, can't connect!
Read through the archives and I believe all the common errors are accounted for. I am about 90% sure it is an Idiot Operator with Limited Networking Skills error related to my firewall.
The Server Ip Address on the port forwarding screenshot, I assume that is the IP Address of the PC in which BI5 is installed? I do have the correct port identified (info stripped off).
The Source and Destination Fields are a question and I tried a few different addresses and still unable to connect. UI3 works if this has any relevance.
Any input would be grand!
ETA - Screen shots removed, looking into VPN.
Read this first. Do not forward any ports!
VPN Primer
VPN Primer
Thanks, I do recall seeing this but it has been a while, my router supports;
OpenVPN vs L2TP/IPSec
Just have to decide which way to go.
