ANPVIZ
wall46
Sep 3, 2018
21
4
Villa Elisa; Paraguay
I'm a BI user for a very long time.
Actual equipment (W10pro, 64GB RAM, 24" ACER 2560x1440 )
1 Gbi CAT5 LAN w/ POE switch for
2 brandnew ANPVIZ uprime PTZ "ANPVIZ PTZ30A60WD-SA-5X(A)"
and
2 seasoned DAHUA SD-22204.
The Dahua's working after a long time of crying and praying. :cool:
Dahua's tools, webpage and service is nearly increasable poor.
But now ANVPIZ is lowering the limits :banghead:
They put an USER GUIDE which didn't mention PTZ30A60WD-SA-5X(A)
nor could find one on their web.
All entries are ridicoulos small text, big nonsense pictures and
sprinkled all over with more tiny chinese letters.
trying hard for many days, but couldn't find any helpful info :puke::eek::mad:
Hope my ginglish is understandable :wave:
It's not clear to me....what is the problem, your question or what is it you are wanting to do? :idk:
I recently purchased one of these ANPVIZ PTZ30A60WD-SA-5X(A) cameras. After I changed the IP Address and Password, I just let ONVIF figure out the settings in Blue Iris. If you leave the settings at default, it gets along nicely with Blue Iris, but the nighttime image quality is very poor (understandably because it is a 6MP camera with a 1/2.8" sensor). I bought the camera knowing it would have poor performance at night. I have been tinkering with running HTTP CGI commands in PowerShell scripts with limited success. Here's a link to their HTTP CGI manual which has been somewhat helpful:
THX for your help. The manual still confuse me and it's not very helpfull, due to the terrible mix of Chinese and English.
one of my two equal ANPVIZ IPcams works w/o any problem, but the other always tells 'No Signal' and 'Decoder not initialized'
I've no clue, what happened and BI Service didn't respond to this item. Instead I should update to BI6 (?!?!?).
I fear, that I'll lose my rest of money for BI5 (expires 04aug2026) and still have the same problem, because I have to import the whole setup for my other cams w/ a lot of PTZ , Video, Database... setups including the 'bad' cam.
Thanks for your help.
Your BI v5 should work OK.
I think that camera is OEM'd by Hikvision. Did you log into the camera at any time using the SADP Tool to initilize it and change it's IP from the default (likely 192.168.1.64) to a unique static IP in the same subnet as your BI server?
Yes but not with this SADPtool. SADPtool find both ANPVIZ cam with (except S/N... cam specific URL...) all other parameters seeming normal.
So I can't find any reason, why BI5 makes me trouble.
Thanks for your help.:)
Did you try deleting the problem camera from BI then re-adding?
Or copy the functioning camera and change only the IP in BI to replacer the problem camera?
Lastly, perform a hard reset of the problem camera and then re-configure and add to BI with "Find/Inspect"?
1st I need a system backup on a new HDD, then I'll try your suggestion. I'll be back, when I found some time.
I'm in a small trouble w/ my health. I'm 80yrs and need some days seeing doctors. Not dangerous but necessary :)
THX for your advice
Reactions: TonyR and looney2ns
Hi TonyR, rescued from the doctors :cool:
now I've done system backup, but can't find how to disable, deleting or restoring... a cam w/ BI5 :banghead:
THX for advice
Found the BI5 option accidently :banghead:
In main panel: Rclick on the cam (my c203) opens a context-sensitive (!!??!!??) window,
where I can choose disable, deleting or restoring... a cam,
(watch the ever changing menu entries :angry: )
but whatever I tried, nothing helps!
The disgusting 'no signal' 'Decoder not initialized' still comes up again.
I've not clue, what to do and BI didn't answer my complaints. Still having a 'premium' support for $ w/o any bang!
Shame on BI and their support.:puke:
I understand from this post last year regarding this same issue that you are "....a retired EE and MSCE engineer and just celebrate my 79th :cool: I have a complete laboratory with tons of tools, parts, including HW tester, oscilloscopes" andf that's great but you do not always follow suggestions or answer questions, such as this one I posted in Sept. of last year. :idk:
Yes, you are right, I've still this problem w/ BI5 and no solution until today. Sorry when I missed one of your posts. I'm not very accustomed with the style of this forum.
Especially on finding, answering and posting pictures... With other forum SW I have less problem. Seems it's my problem: "A man's got to know his limitations" ;)
Sorry once more. THX for your time.
