BI Audio Trigger?
mike s.
Dec 12, 2014
40
4
Am wondering why my BI video recording isn't triggering by sound. BI supposedly can "use motion or audio sensing to trigger recording," per a Google search, so I guess I have something set up wrong. Video recording triggered by motion works fine, but my BI isn't triggering for just sound. Would appreciate a hint to the setup for that....
Thx
Thx
1. Open Blue Iris console
2. Right click on the specific camera and then select camera properties
3. Select the Audio tab
4. Make sure the following is selected or enabled:
* Enable Audio Channel
* Trigger the camera during profiles
* Profiles 1-7
* Use 1 second average intensity
* Adjust "Sensitivity" up to MAX.
See help for more info:
You may choose to Trigger the camera when loud-enough noises are detected. The camera's trigger "break time" is used to end recording regardless of whether or not you have the video motion sensor enabled. You may adjust the sensitivity of the audio trigger (the loudness of the audio signal which will cause recording to begin). When the slider is toward the left, only very loud sounds will trigger recording. When the slider is toward the right, small sounds will also trigger recording. Maximum sensitivity is achieved when the microphone gain is high (or at max) and the trigger sensitivity is high (or at max). Beneath the sensitivity slider is an audio power meter, which will show the current strength of the audio signal. When the signal is sufficient to trigger recording, the meter will show in red. This meter may only be available once the audio source has been initialized (that is, you Ok the camera property window, and then return to this properties page).
By default, a 1 second average intensity is used for the audio trigger. With this option enabled, only longer/sustained noises will result in a trigger. With this option disabled, short noises such as a single hand-clap may be capable of triggering the camera.
Reactions: MuchBarking
Ok, thank you, am trying that. I already had all those settings, except that the sensitivity was only about half-max.
