I am trying to view cameras (LBV2521-C) connected to a Lorex LH2116 DVR and having a hard time configuring BI.
Learned from another post I might have to create a user name ( non-admin) for each cam and add each cam using the newly created accounts on the Lorex DVR. Created user BICAM1 and I am able to open the camera on VLC with the following command:
rtsp://BICAM1
assword@192.168.1.89:80/cam/realmonitor?channel=1&subtype=1
However, I can't figure out how to configure it in BI.
Here is my info:
BI CAMERA VIDEO--> Find/Inspect returns the following:
Opening 192.168.1.89 port 80...
HTTP Get / request...
OK
ONVIF GetSystemDateAndTime
HTTP 404
Opening 192.168.1.89 port 8999...
HTTP 12029
Checking for common cameras...
Foscam FI86xx/98xx compatible?
Foscam FI89xx compatible?
Foscam FI9821 V2 compatible?
Foscam FI9821 media port compatible?
RTSP port open?
RTSP port detected!
Done
here are my camera selection and settings ( path and params are based on selection of Make & model)
Make: Lorex
Model: LHV2116 RTSP
Video Path: /cam/realmonitor
Video params:channel={CAMNO}&subtype=0&authbasic={AUTH64}
Video Camera:1
Note: for some reason even though I specify the port on the address, I noticed it gets removed by BI.
I think the problem is the BI RTSP URL. I am not sure how BI is using the info on the video configuration to build the RTSP URL and hoping for some assistance.
Attached are screenshots of my settings.
Thanks in advance!
rtsp://BICAM1
Here is my info:
OK
HTTP 404
HTTP 12029
RTSP port open?
RTSP port detected!
Done
Make: Lorex
Model: LHV2116 RTSP
Video Camera:1
Thanks in advance!
