- Sep 25, 2017
- 3,167
- 4,099
Hi,
I'm having some Bit Rate Issues. I'm on an older BI build atm until I can get some PC backup software as everytime I update and AI gets upset, I end up having to do a total clean Windows Installation to fix it!
So the issue I'm having is what I've always seen - my 4k camera's mainstream has been reported in BI as being full hd and locked at 4000kbs. Since installing my replacement camera this has fallen to 2000kbs. My sub stream suffers the same. Set to full hd and 4000kbs, reported at 1080P but at 1,000kbs.
BI has always locked me to full hd. In the Video tab anything higher 1080P is unavailable. FPS set to 15fps with 66 kbs the top 15fps preset it offers me.
I thought this was misreporting, but since dropping to 2000kbs, I can see issues with the picture quality during the day - it's lost some sharpness and there's some blur / pixellation of movement ie people leading me to believe the bit rates may in fact be correct. Exposure is set to 6ms, gain 0-20 (as shady spot under a car port), NR etc on. So no obvious setting reason.
When I check the LAN properties BI > Switch, they're reported as Megabit connection making me suspect it's not the cable as communication link appears fine. Cable has been tested for connection integrity using a tester (but not speed other than LAN properties).
Any suggestions? I'm struggling to think where to go here. Are there limitation in BI on receiving 4k? If so, why has it changed without an update?
