Blue Iris Instant Crashing
Jul 31, 2018
1
United States
I've been having this issue for awhile now. I cannot get Blue Iris to start for more than a few seconds. I'm running on Server 2022. I've never had this issue. I've uninstalled Blue Iris using Revo uninstaller and cleared the registry and I keep getting the same Event Viewer dump. I really don't want to reformat Windows if I don't have to do so. I've run all the SFC checks and there is no issues found. I've combed the forums for a solution, but there's a lot of parallel conversations that don't give me resolution. Please help me.
[td width="130px"][/td]
[td]BlueIris.exe[/td]
[td]5.7.8.1[/td]
[td]64bc2070[/td]
[td]ntdll.dll[/td]
[td]10.0.20348.2849[/td]
[td]91e17825[/td]
[td]c0000005[/td]
[td]00000000000a9648[/td]
[td]1f48[/td]
[td]01db45af23104788[/td]
[td]H:\Program Files\Blue Iris 5\BlueIris.exe[/td]
[td]C:\Windows\SYSTEM32\ntdll.dll[/td]
[td]60f79db5-3b8c-4458-b356-0181a5e1d7c0[/td]
Faulting application name: BlueIris.exe, version: 5.7.8.1, time stamp: 0x64bc2070
Faulting module name: ntdll.dll, version: 10.0.20348.2849, time stamp: 0x91e17825
Exception code: 0xc0000005
Fault offset: 0x00000000000a9648
Faulting process id: 0x1f48
Faulting application start time: 0x01db45af23104788
Faulting application path: H:\Program Files\Blue Iris 5\BlueIris.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: 60f79db5-3b8c-4458-b356-0181a5e1d7c0
Faulting package full name:
Faulting package-relative application ID:
Did BI successfully run on this installation previously or is this a new deployment of BI and/or 2022 Server?
Have you installed and/or updated VC_REDIST?
Are you using an account that is in Administrators group?
While BI can be installed and made to operate correctly on server, it typically requires a few extra components to be installed. I’ve not used server for a long time and don’t remember which additional components beyond vc_redist that are needed.
