Blue Iris schedule help
Cleve
Mar 3, 2021
184
29
Alabama
I have three schedules set up in blue iris. 1-Home, 2-Away, and 3-Night. I have one camera that has two presets. In schedule 1 its set to preset 1. In schedule two, set to preset 2. I want it to remain on preset 1 when I am at home and got to preset 2 when I am away. Schedule 3 runs from 11:59 PM until 6:00 AM. I would like the camera to go to preset 2 during schedule 3 even if I am home. I had this set up at one time but it has stopped working. I did get it to change preset at 11:59 but I can't get it to return to preset 1 at 6:00 AM. I have attached a copy of the action sets I have. Any suggestions on how to fix this? Thanks
Is this the Action set for the ‘On schedule change’ button on the Settings>Schedule tab?
Can you move the camera to preset 2 using the BI interface? If not, you might need to Find/inspect the camera again on the Camera settings > Video> Configure tab
I can change the camera's presets using the Blue Iris interface. The settings I used are in the Cameras schedule tab, on profile change, button. I have attached a screen shot of the cameras schedule tab. I may have a check in the wrong box, not sure.
Additionally, it is worth noting that Preset commands in Action sets can be overridden by a camera's Events schedule action set.
Specifically, check if setting 'Search back back at startup/reset' is enabled in the Camera settings > Schedule > Events schedule > Action set.
For example,
With these camera settings, the camera's profile never changes; hence the action set is never triggered.
I'm not sure without testing, but It may get triggered when Blue Iris starts.
I think I figured it out. I have unchecked the "override global schedule" and It will respond when I manually change the profile. I will have to wait till next year now to see if it works. Thanks for the help.
For testing if an Action set is actually triggered, you could add a 'Push notification' Action to the Action set.
When I'm logged onto the BI PC, I actually prefer a 'Run a program' action like this
For example,
It is checked. I think I have it fixed. I have changed my internet provider recently and had some problems after that with blue iris because the IP address kept getting changed but it was most likely something I did that got it messed up.
