Blue Iris UI3
First thanks for this great addition to Blue Iris. I have only been using it a few days, but really appreciate the customization options and quick response. I do have a question or feature request. I'm trying to use ui3 with Plastuer which allows it to run as a "wallpaper" so that it is always view-able on the background and so far things work great with good performance and I have been able to get everything to work using the group and maximize options in the http line. The issue is that while running via Plastuer I don't have access to some of the menus and it appears to use its own embedded version of Chromium and I have been unable to figure out how to modify the settings.
The issue comes around the timeout. Is there another location that the timeout can be set to 0 or a parameter that is available or could be added to the http: url to allow the timeout to be set to infinite?
Thanks,
Jeff
Yeah.
  1. Log in to UI3 from a normal browser, using a Blue Iris administrator account. If you logged in anonymously and your Anonymous account doesn't have admin rights, just try to access any feature that requires admin privilege and a login form will appear.
  2. Set all settings the way you like them (including the timeout).
  3. Scroll to the very bottom of UI settings.
  4. The very bottom item should read: Create Script: "ui3-local-overrides.js". Click the Download button. A copy of all your current settings will be downloaded to a file called ui3-local-overrides.js
  5. Move or copy the downloaded script file into your ui3beta/ui3/ directory. The settings from the overrides script will be applied as the new defaults.
Don't have an IOS device, but android has no issues as far as i can see.
Can you open the browser's developer tools and see if the console spews any related error messages when the stream fails? (developer tools are accessible via the browser's main menu, typically, or CTRL + SHIFT + I on chrome)
F12 it is! Here's the output...
When logging in on initial load up... (will update the beta to b25 later today, this issue has been persistent on all betas for whatever its worth)
ui3-local-overrides.css Failed to load resource: the server responded with a status of 404 (Not Found)
09:01:54.699 ui3-local-overrides.js Failed to load resource: the server responded with a status of 404 (Not Found)
09:01:54.743 ui3-local-overrides.js Failed to load resource: the server responded with a status of 404 (Not Found)
09:01:54.782 ui3.js?v=b23-4.6.7.1:12393 [Deprecation] GainNode.gain.value setter smoothing is deprecated and will be removed in M64, around January 2018. Please use setTargetAtTime() instead if smoothing is needed. See https://www.chromestatus.com/features/5287995770929152 for more details.
PcmAudioPlayer.SetVolume @ ui3.js?v=b23-4.6.7.1:12393
09:01:54.782 ui3.js?v=b23-4.6.7.1:12393 [Deprecation] AudioParam value setter will become equivalent to AudioParam.setValueAtTime() in M65, around March 2018  See https://webaudio.github.io/web-audio-api/#dom-audioparam-value for more details.
09:01:54.872 ui3.htm:1 [DOM] Password field is not contained in a form: (More info: https://goo.gl/9p2vKq) <input type="password" varname="pass" placeholder="Password" onkeypress="return sessionManager.PwKeypress(this,event)">
09:01:54.891 json Failed to load resource: the server responded with a status of 404 (Not Found)
09:01:54.950 ui3.js?v=b23-4.6.7.1:13676 success toast: Logged in as Brett<br/>(Administrator)<br/><br/>Server "Main-Home"<br/>Blue Iris version 4.6.7.1
09:01:55.084 ui3.js?v=b23-4.6.7.1:13676 info toast: Welcome to the UI3 beta test!<br><br>UI3 beta version: b23<br>Blue Iris version: 4.6.7.1<br><br><a href="javascript:UIHelp.LearnMore('beta_information')" style="color: #00ff00; font-weight: bold; font-size: 1.4em;">Click here to learn more or to provide feedback.</a>
09:01:55.244 preset_1.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.246 preset_2.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.246 preset_3.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.254 preset_4.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.255 preset_5.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.258 preset_6.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.263 preset_7.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.266 preset_9.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.267 preset_8.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.270 preset_10.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.273 preset_11.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.274 preset_12.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.277 preset_13.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.282 preset_14.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.286 preset_15.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.287 preset_16.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.290 preset_17.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.293 preset_18.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.294 preset_19.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.320 preset_20.jpg Failed to load resource: the server responded with a status of 503 (Service Unavailable)
09:01:55.983 ui3-local-overrides.css Failed to load resource: the server responded with a status of 404 (Not Found)
1709:02:05.125 XHR finished loading: POST "<URL>".
09:02:18.398 ui3.js?v=b23-4.6.7.1:9327
When mousing over an alert image, the console returns the following... (wall of verbosity)
@14735655096.mp4:1 GET http://192.168.20.5:8171/file/clips/@14735655096.mp4?time=0&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
attr @ libs-ui3.js?v=b23-4.6.7.1:5
m.access @ libs-ui3.js?v=b23-4.6.7.1:4
BigThumbHelper.Show @ ui3.js?v=b23-4.6.7.1:4481
ClipThumbnailVideoPreview_BruteForce.Start @ ui3.js?v=b23-4.6.7.1:5863
(anonymous) @ ui3.js?v=b23-4.6.7.1:5827
setTimeout (async)
ClipThumbnailVideoPreview_BruteForce.Start @ ui3.js?v=b23-4.6.7.1:5822
(anonymous) @ ui3.js?v=b23-4.6.7.1:5192
handle @ libs-ui3.js?v=b23-4.6.7.1:4
dispatch @ libs-ui3.js?v=b23-4.6.7.1:4
r.handle @ libs-ui3.js?v=b23-4.6.7.1:4
09:05:41.672 @14735655096.mp4:1 GET http://192.168.20.5:8171/file/clips/@14735655096.mp4?time=4250&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
(anonymous) @ ui3.js?v=b23-4.6.7.1:5876
imgErrored @ ui3.js?v=b23-4.6.7.1:4460
09:05:42.024 @14735655096.mp4:1 GET http://192.168.20.5:8171/file/clips/@14735655096.mp4?time=8500&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:42.381 @14735655096.mp4:1 GET http://192.168.20.5:8171/file/clips/@14735655096.mp4?time=12750&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:42.740 @14735655096.mp4:1 GET http://192.168.20.5:8171/file/clips/@14735655096.mp4?time=17000&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:43.116 @14735655096.mp4:1 GET http://192.168.20.5:8171/file/clips/@14735655096.mp4?time=21250&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:43.487 @14735655096.mp4:1 GET http://192.168.20.5:8171/file/clips/@14735655096.mp4?time=25500&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:43.867 @14735655096.mp4:1 GET http://192.168.20.5:8171/file/clips/@14735655096.mp4?time=29750&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:45.110 @14735930833.mp4:1 GET http://192.168.20.5:8171/file/clips/@14735930833.mp4?time=0&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:46.088 @14795674374.mp4:1 GET http://192.168.20.5:8171/file/clips/@14795674374.mp4?time=0&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:47.571 @14795674374.mp4:1 GET http://192.168.20.5:8171/file/clips/@14795674374.mp4?time=0&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
setTimeout (async)
09:05:47.992 @14795674374.mp4:1 GET http://192.168.20.5:8171/file/clips/@14795674374.mp4?time=1250&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:48.384 @14795674374.mp4:1 GET http://192.168.20.5:8171/file/clips/@14795674374.mp4?time=2500&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:48.755 @14795674374.mp4:1 GET http://192.168.20.5:8171/file/clips/@14795674374.mp4?time=3750&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:49.123 @14795674374.mp4:1 GET http://192.168.20.5:8171/file/clips/@14795674374.mp4?time=5000&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:49.495 @14795674374.mp4:1 GET http://192.168.20.5:8171/file/clips/@14795674374.mp4?time=6250&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:49.885 @14795674374.mp4:1 GET http://192.168.20.5:8171/file/clips/@14795674374.mp4?time=7500&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:50.292 @14795674374.mp4:1 GET http://192.168.20.5:8171/file/clips/@14795674374.mp4?time=8750&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:50.661 @14795674374.mp4:1 GET http://192.168.20.5:8171/file/clips/@14795674374.mp4?time=0&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:51.315 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=0&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:51.692 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=1250&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:52.093 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=2500&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:52.469 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=3750&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:52.857 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=5000&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:53.240 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=6250&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:53.644 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=7500&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:54.054 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=8750&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:54.437 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=0&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:54.851 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=1250&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:55.231 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=2500&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:55.609 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=3750&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:55.993 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=5000&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:56.387 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=6250&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:56.795 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=7500&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:57.205 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=8750&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:57.595 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=0&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:58.025 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=1250&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:58.420 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=2500&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:58.815 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=3750&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:59.234 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=5000&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:05:59.647 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=6250&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:06:00.036 @14736520963.mp4:1 GET http://192.168.20.5:8171/file/clips/@14736520963.mp4?time=7500&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
When left clicking an alert, i get the following...
ui3.js?v=b23-4.6.7.1:13953 GET http://192.168.20.5:8171/file/clips/@14736280158.mp4?session=10d33c446c8a34510323511f4c2144cd&speed=100&audio=0&stream=0&extend=2&time=49958 503 (Service Unavailable)
Start @ ui3.js?v=b23-4.6.7.1:13953
FetchVideoH264Streamer @ ui3.js?v=b23-4.6.7.1:14184
OpenStreamNow @ ui3.js?v=b23-4.6.7.1:13869
StreamEndedWrapper @ ui3.js?v=b23-4.6.7.1:13881
CallStreamEnded @ ui3.js?v=b23-4.6.7.1:13993
(anonymous) @ ui3.js?v=b23-4.6.7.1:14012
Promise.then (async)
pump @ ui3.js?v=b23-4.6.7.1:14008
(anonymous) @ ui3.js?v=b23-4.6.7.1:14075
(anonymous) @ ui3.js?v=b23-4.6.7.1:14142
09:07:49.263 ui3.js?v=b23-4.6.7.1:13676 warning toast: The video stream was lost. Attempting to reconnect...
609:07:59.011 Fetch failed loading: GET "<URL>".
09:07:49.275 ui3.js?v=b23-4.6.7.1:13953 Fetch failed loading: GET "http://192.168.20.5:8171/file/clips/@14736280158.mp4?session=10d33c446c8a34510323511f4c2144cd&speed=100&audio=0&stream=0&extend=2&time=49958".
09:07:51.709 ui3.js?v=b23-4.6.7.1:13953 Fetch failed loading: GET "http://192.168.20.5:8171/file/clips/@14736280158.mp4?session=10d33c446c8a34510323511f4c2144cd&speed=100&audio=0&stream=0&extend=2&time=49970".
safeFetch.OpenStream @ ui3.js?v=b23-4.6.7.1:13844
FetchOpenH264VideoModule.OpenVideo @ ui3.js?v=b23-4.6.7.1:8761
ReopenStreamAtCurrentSeekPosition @ ui3.js?v=b23-4.6.7.1:8896
setTimeout (async)
StreamEnded @ ui3.js?v=b23-4.6.7.1:8944
StreamEndedWrapper @ ui3.js?v=b23-4.6.7.1:13880
protocolError @ ui3.js?v=b23-4.6.7.1:13999
(anonymous) @ ui3.js?v=b23-4.6.7.1:14040
(anonymous) @ ui3.js?v=b23-4.6.7.1:13982
Start @ ui3.js?v=b23-4.6.7.1:13956
09:07:54.114 ui3.js?v=b23-4.6.7.1:13953 Fetch failed loading: GET "http://192.168.20.5:8171/file/clips/@14736280158.mp4?session=10d33c446c8a34510323511f4c2144cd&speed=100&audio=0&stream=0&extend=2&time=49970".
setTimeout (async)
setTimeout (async)
09:07:56.534 ui3.js?v=b23-4.6.7.1:13953 Fetch failed loading: GET "http://192.168.20.5:8171/file/clips/@14736280158.mp4?session=10d33c446c8a34510323511f4c2144cd&speed=100&audio=0&stream=0&extend=2&time=49970".
setTimeout (async)
setTimeout (async)
setTimeout (async)
09:07:58.961 ui3.js?v=b23-4.6.7.1:13953 Fetch failed loading: GET "http://192.168.20.5:8171/file/clips/@14736280158.mp4?session=10d33c446c8a34510323511f4c2144cd&speed=100&audio=0&stream=0&extend=2&time=49970".
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
09:08:01.368 ui3.js?v=b23-4.6.7.1:13953 Fetch failed loading: GET "http://192.168.20.5:8171/file/clips/@14736280158.mp4?session=10d33c446c8a34510323511f4c2144cd&speed=100&audio=0&stream=0&extend=2&time=49970".
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
09:07:50.325 @14735930833.mp4:1 GET http://192.168.20.5:8171/file/clips/@14735930833.mp4?time=0&h=240&session=10d33c446c8a34510323511f4c2144cd 503 (Service Unavailable)
Image (async)
09:07:51.693 ui3.js?v=b23-4.6.7.1:13953 GET http://192.168.20.5:8171/file/clips/@14736280158.mp4?session=10d33c446c8a34510323511f4c2144cd&speed=100&audio=0&stream=0&extend=2&time=49970 503 (Service Unavailable)
setTimeout (async)
09:07:51.695 ui3.js?v=b23-4.6.7.1:13676 warning toast: The video stream was lost. Attempting to reconnect...
09:07:54.098 ui3.js?v=b23-4.6.7.1:13953 GET http://192.168.20.5:8171/file/clips/@14736280158.mp4?session=10d33c446c8a34510323511f4c2144cd&speed=100&audio=0&stream=0&extend=2&time=49970 503 (Service Unavailable)
setTimeout (async)
setTimeout (async)
09:07:54.100 ui3.js?v=b23-4.6.7.1:13676 warning toast: The video stream was lost. Attempting to reconnect...
09:07:56.518 ui3.js?v=b23-4.6.7.1:13953 GET http://192.168.20.5:8171/file/clips/@14736280158.mp4?session=10d33c446c8a34510323511f4c2144cd&speed=100&audio=0&stream=0&extend=2&time=49970 503 (Service Unavailable)
setTimeout (async)
setTimeout (async)
setTimeout (async)
09:07:56.520 ui3.js?v=b23-4.6.7.1:13676 warning toast: The video stream was lost. Attempting to reconnect...
09:07:58.944 ui3.js?v=b23-4.6.7.1:13953 GET http://192.168.20.5:8171/file/clips/@14736280158.mp4?session=10d33c446c8a34510323511f4c2144cd&speed=100&audio=0&stream=0&extend=2&time=49970 503 (Service Unavailable)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
09:07:58.946 ui3.js?v=b23-4.6.7.1:13676 warning toast: The video stream was lost. Attempting to reconnect...
09:08:01.347 ui3.js?v=b23-4.6.7.1:13953 GET http://192.168.20.5:8171/file/clips/@14736280158.mp4?session=10d33c446c8a34510323511f4c2144cd&speed=100&audio=0&stream=0&extend=2&time=49970 503 (Service Unavailable)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
setTimeout (async)
09:08:01.350 ui3.js?v=b23-4.6.7.1:13676 error toast: The video stream was lost.  Due to rapid failures, automatic reconnection will not occur.
09:08:24.870 libs-ui3.js?v=b23-4.6.7.1:4 [Violation] Added non-passive event listener to a scroll-blocking 'touchmove' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952
add @ libs-ui3.js?v=b23-4.6.7.1:4
(anonymous) @ libs-ui3.js?v=b23-4.6.7.1:4
each @ libs-ui3.js?v=b23-4.6.7.1:2
on @ libs-ui3.js?v=b23-4.6.7.1:4
ClipTileCreate @ ui3.js?v=b23-4.6.7.1:5181
ClipOnAppear @ ui3.js?v=b23-4.6.7.1:5131
ClipListDynamicTileLoader.appearDisappearCheck @ ui3.js?v=b23-4.6.7.1:6128
ClipListDynamicTileLoader.resizeClipList @ ui3.js?v=b23-4.6.7.1:6220
ClipLoader.resizeClipList @ ui3.js?v=b23-4.6.7.1:4912
resized @ ui3.js?v=b23-4.6.7.1:1671
(anonymous) @ ui3.js?v=b23-4.6.7.1:4838
success @ ui3.js?v=b23-4.6.7.1:13312
j @ libs-ui3.js?v=b23-4.6.7.1:2
fireWith @ libs-ui3.js?v=b23-4.6.7.1:2
x @ libs-ui3.js?v=b23-4.6.7.1:5
b @ libs-ui3.js?v=b23-4.6.7.1:5
09:08:24.870 libs-ui3.js?v=b23-4.6.7.1:4 [Violation] Added non-passive event listener to a scroll-blocking 'touchstart' event. Consider marking event handler as 'passive' to make the page more responsive. See https://www.chromestatus.com/feature/5745543795965952
If i directly access the video clip, via http://192.168.20.5:8171/clips/@14812329688.mp4 - it's fully functional and will play the video from start to finish.
I can also right click the alert, download the alert, and it plays back the full minute of the file. The file is saved as "WestPTZ 2018-1-28 06.50.52.mp4" as it was sent from the BI/UI3 daemon/console/web ui.
For whatever it's worth, here's the meta data from the recorded videos as per MPC-HC...
General
Complete name                  : C:\Users\Brett\Downloads\WestPTZ 2018-1-28 06.50.52.mp4
Format                         : MPEG-4
Format profile                 : Base Media
Codec ID                       : isom (isom/iso2/avc1/mp41)
File size                      : 60.0 MiB
Duration                       : 59 s 946 ms
Overall bit rate               : 8 400 kb/s
Writing application            : Lavf57.71.100
Video
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : Main@L4.2
Format settings, CABAC         : Yes
Format settings, RefFrames     : 1 frame
Codec ID                       : avc1
Codec ID/Info                  : Advanced Video Coding
Bit rate                       : 8 390 kb/s
Width                          : 1 920 pixels
Height                         : 1 080 pixels
Display aspect ratio           : 16:9
Frame rate mode                : Variable
Frame rate                     : 30.000 FPS
Minimum frame rate             : 28.571 FPS
Maximum frame rate             : 250.000 FPS
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Bits/(Pixel*Frame)             : 0.135
Stream size                    : 60.0 MiB (100%)
The machine these mp4 videos and alerts are saved to is on a 6TB drive named R:\ - model is ST6000VX0023. Drive is solely used for video storage within R:\blueiris\New, R:\blueiris\Stored, R:\blueiris\Alerts.
The drive with the snapshot stills are on a Samsung SSD 850 EVO 500GB, in the D:\ drive, specially in (D:\blueiris\Snapshots). The Blue Iris install is on the C:\ Drive SSD - Samsung 850 EVO 500GB.
Yeah.
It would be great to have the most used settings exposed in GUI and available for editing when an Admin-level account is logged in. Low priority feature request, of course. :-)
It would be great to have the most used settings exposed in GUI and available for editing when an Admin-level account is logged in. Low priority feature request, of course. :)
Not possible without a major settings overhaul and support from the server ;)
Thank you. So, Blue Iris is returning 503 (Service Unavailable) in response to requests for jpegs or streams from the mp4 file, yet the mp4 files are playable in VLC and Blue Iris definitely knows where they're at because you can download them through the web server. I'm not sure what would cause this. You say the same alerts play fine in the android app? Do they also play fine in the Blue Iris local console? This surprises me because it seems like your Blue Iris PC might not have the necessary codecs for Blue Iris to decode and play those MP4s, but if that was the case then those alerts shouldn't be playable in any Blue Iris player.
It is a long shot, but you could try installing the k-lite codec pack to see if that fixes this issue. Ninite should be able to install it easily and without any adware. Ninite K-Lite Codecs Unattended Silent Installer and Updater You may need to restart Blue Iris after installing.
The long shot worked. Alert playback is functioning with the K-Lite reinstall. Had to close down BI before the installer could finish however.
Reactions: bp2008
Regarding UI3Beta, I use CCleaner to keep my cookies cleaned up. I can save the ones I want. I haven't found the UI3 cookies. So when I run CCleaner I loose my UI3 settings. What are they named? Thanks!
I found three candidates: bidagent.xad.com, bidr.lo, and bidswithch.net.
This question only pertains to UI3. I ran a test. I used CCleaner to delete all cookies. Then ran UI3. I had to re-enter the UID/PW and then set the timeout setting to 0. I let it run a few minutes and shut it down. I then reran CCleaner and found no cookies. But the UID.PW, etc were deleted. When you say "local storage", what do you mean? I can have CCleaner ignore any cookies, including those by IP address. I do this routinely for my cameras, since they do use cookies. I'm not sure where to go from here.
Local Storage is a feature of modern browsers that lets web pages store data, similar to cookies, except cookies are always transmitted to the server with each web request and Local Storage data is not. Local Storage data has much looser limits (it can hold more data).
It is just one of several methods a web page can use to store data that CCleaner might be interfering with. They might be just calling everything "Cookies" because that is what normal users are most familiar with.
I found where the local storage is stored and added an exclude for that file location to CCleaner. CCleaner no longer deletes my UI3 settings...
Thanks for your help bp!
Hope I didn't miss this, but, using the latest Beta (and some versions before), if I'm viewing clips that auto play then go full screen '`', the clips stop at the end of the clip that was playing.
I believe I know what is wrong. This would have gotten broken back when I changed the clip list to automatically delete clip tiles that go off-screen. It was an important performance optimizaiton. I didn't realize it would have an impact on autoplay (and probably the up/down hotkeys too). I'll have to decouple that clip switching logic from the GUI, like it should have been in the first place.
Reactions: Nashional
Beta b25 is available in the first post.
* Fixed programmatic and hotkey-controlled clip switching when GUI is hidden.
* Fixed audio controls appearing if jpeg streaming is the default streaming type, and only disappearing after switching to H.264 and back.
* Fixed bug where attempting to seek via buttons beyond the clip boundaries leaves the loading animation up indefinitely (in Jpeg mode).
