Blue Iris v3.0.37 lagging on Android V11
rebelbah
Mar 11, 2015
118
9
in the last several weeks Blue Iris has been lagging when connecting to the cameras.
when you select the server you want to view it connects fairly quickly, when you select the camera icon to view the cameras it takes up to 45 seconds to show the camera feeds and sometimes then you try scroll the feeds and it hangs, when you select a feed it takes up to 30 seconds. I have access to several BI systems, this even happens when connected on the same network.
any suggestions?
Almost instant for me, v3.0.37 but I'm on Android v12, so there is a difference there. Have you rebooted the device? Always the first step that I take.
Which version of Blue Iris? 5.5.6.5 is what I'm on.
1 on BI v 5.4.9.18
1 on 5.5..... latest version
1 on 5.5.4.3
update BI version 5.5.6.21
android v 12
still having the issue of BI on android opening pretty quick when you click the server to connect to , but when trying to view cameras it takes a while to pull the live and last feed page.
have updated windows and all software(BI, android.....) and rebooted everything including cameras
any suggestions
only antivirus is defender, and it happens the same when connected locally "same LAN network"
I disabled defender and same result.
I have access to 3 different Blue Iris machines and the same thing happening, all running under 20% cpu
rebuilt database , restarted machine , made sure defender was off and same issue,
using 10%cpu , 14% ram
