kc8tmv Getting the hang of it May 27, 2017 207 94 Cincinnati, Ohio Friday at 2:44 PM #1 Device: IPC-HDBW5441F-AS-E2-3.6mm System Version: V2.840.15OG001.0.R, Build Date: 2021-07-31 Web Version: V3.2.1.1096661 ONVIF Version: 20.12(V3.0.0.1030855) Are these the ONLY Sub Stream Resolutions available? Can someone confirm if this is the latest firmware? 704*576 640*480 352*288
chaosengine Getting the hang of it Dec 11, 2017 136 81 Germany Friday at 6:58 PM #2 Look at Sub Stream 2 Reactions: kc8tmv and VorlonFrog
VorlonFrog IPCT+ Member Aug 3, 2015 5,585 20,575 Land of the free Friday at 6:59 PM #3 That's all I've got for substream resolutions on mine: Here's my firmware information: @chaosengine is correct, above. there's a drop-down where you can select Sub-Stream 2 and it provides more resolutions.
kc8tmv Getting the hang of it May 27, 2017 207 94 Cincinnati, Ohio Friday at 7:07 PM #4 chaosengine said: Look at Sub Stream 2 Click to expand... Thank you so much! Vielen Dank! I didn't even realize there was a dropdown arrow there! Reactions: chaosengine
redpoint5 Getting comfortable May 12, 2020 575 1,700 PDX Saturday at 2:02 AM #5 I did not click the link based on the title, honest. Thought it said Bobby cam, which is a better excuse, somehow.
