Built in AI - Face detection / unknown faces
scoob8000
Dec 28, 2018
152
65
PA
I've been playing aruond with this but can't seem to get it to save any unknown faces.
I have F:\bifaces created, gloabal AI face detection settings set to use it, Aux13 is set to it, and I've set several cams to use face detection and save unknown to Aux13.
I'm seeing in the AI analysis a box around the unknown face with the label unknown, but it's not saving them. Assuming I'm missing something obvious here.
I too am having the same issue, using BI6. If I use AI analysis it shows a unknown box around a persons face, but won't save the image when the camera is triggered.
Here are my settings
Reactions: scoob8000
I managed to get this working with the help of Ken, you need to ensure Object Detection is enabled.
Mind comparing some settings? If all looks good I'll shoot Ken a email..
My aux13 is set in storage to f:\bifaces
You'll need to check object tracking, this is the key!
Also increase your maximum connections
Then check your folder f:\bifaces for new images, once they are found, you would manually create a new directory for each person to detect, eg f:\bifaces\Tom
Then you put images of Tom in f:\bifaces\Tom. and the go into the settings > Faces, and it should analysise the images, and show the ones where a face was found.
Eg
Cheers
Reactions: GuiBou
