Camera for blind spot
amrogers3
Sep 1, 2021
197
128
Houston
I have a blind spot by the garage door. I have cameras covering most of the driveway but I missing the area from the garage door out to about 5 feet. Someone could easily hide in this spot and I wouldn't be able to see them. I already ran the cable where I would like to mount the camera.
I am trying to find a camera with audio linkage that broadcast, "you are under surveillance" when tripwire is broken. Dahua doesn't give the ability to search for cameras with this feature unless they are calling it something else.
Any recommendations for a camera with audio linkage that would effectively cover this spot?
approximate blind spot area:
You might check out the Dahua HDW3249H-AS-PV camera. It's only 2mp, but since you only want footage up close it shouldn't matter. With it's 1/2.8" sensor and the low 2mp resolution, you should get decent low/no light performance. It is part of Dahua's Active Deterrence line and I believe you can upload a custom audio file to play when the camera triggers.
