Hi all,
I have a home similar to the one posted below and need your advice on camera placement and camera models. I have marked in red the spots I want to put a camera. My issue is running the cables...I have an unfinished basement that I want to run all the cables down to but dont know what the best route might be. How would you recommend I install the camera near the front door? should I run the cable to the right side of the house and then drill into the basement?
For the camera on top of the garage door and left side of the house - should I run the cables into the garage somehow and then put a POE switch and wireless extender?
I was even thinking of not mounting a camera at the top left corner if the garage camera gets good coverage. What model ip cameras would you guys recommend I use? I am considering going with a Lorex 8 camera/dvr kit. I am in Toronto btw.Thanks in advance.
